When loading custom size paper in the multi-purpose tray
Load them the same way as standard size paper.
For details on the paper that you can load in the paper drawer, see "Usable Paper."
Load paper in Drawer 2 (optional) in the same manner as you load paper in Drawer 1.
Before loading paper, see "Attention (Paper Drawer)."
(1)
Hold the lock release lever.
(2)
Slide the paper guides to the position of the size of the paper to be loaded.
Align the position of (A) with the size mark of the paper to be loaded.
The side paper guides move together.
(1)
(2)
Slide the paper guide to the position of the size of the paper to be loaded.
When loading paper with a letterhead or logo
See "Paper Loading Orientation" and load the paper in the correct orientation.
Be sure to adjust the paper guides to the stack of paper so as to leave no space in between.
If the paper guides are too loose or too tight, this may result in paper being misfed or paper jams.
Be sure that the paper stack does not exceed the load limit mark lines. If the paper stack exceeds the load limit mark lines, this may result in paper being misfed.
