Do not turn the printer ON immediately after turning it OFF.
If you want to cycle the power of the printer, wait at least 10 seconds before turning it ON again.
If the printer does not operate properly
If an error message appears in the display on the control panel
When turning ON the printer for the first time after installing the printer and paper feeder
Do not load paper in the paper drawer.
Precautions when turning OFF the printer
If you turn the printer OFF, all print data remaining in the printer memory will be erased.
When you attempt to turn the printer OFF suddenly, an unexpected error may occur. Use the procedure described in the e-Manual to turn the printer OFF.
Power consumption when the power is OFF
Even if the printer is turned OFF, power is still consumed slightly while the power plug is inserted in the AC power outlet.
To stop the power consumption completely, unplug the power plug from the AC power outlet. |
