: You can enter the menu
: You cannot enter the menu|
When the printer is online
When the printer is offline
[Setup] menu
[Select Feeder] menu
[Reset] menu
[Job] menu
[Utility Menu] menu
Application menu
The [User Maintenance] options cannot be specified when the printer is online.
Online).
Online indicator turns on, and the printer is online.|
If you cannot place the printer online
If an error is occurring in the printer, the printer does not come online.
Eliminate the cause of the error before you place the printer online. |
About the
Online indicator during Sleep ModeDuring Sleep Mode, the
Online indicator is off even when the printer is online. |
Online).
Online indicator goes off, and the printer is offline. |
About the automatic online function
You can specify the time interval until the printer automatically enters the online status. The default is [2 minutes].
The printer does not automatically enter online status in the following cases.
The printer is in error status.
The printer is in Sleep mode.
[Auto Reset Time] under [Timer Settings] is set to [Off].
