Before loading paper, see "Important Safety Instructions."
When loading paper for the first time after installing the paper feeder
Before loading paper, be sure to turn ON the printer once.
Do not touch the black rubber pad (A) in the paper drawer.
This may result in paper being misfed.
![]() Do not pull out the paper drawer during printing.
This may result in paper jams or damage to the printer.
When using paper that is poorly cut
Multiple sheets of paper may be fed at a time. In this case, fan the paper thoroughly, and then align the edges of the stack properly on a hard, flat surface.
When loading A5 paper
The orientation setting to be selected on the control panel depends on how you load paper. Select the correct setting.
For paper orientation and printing side, see "Paper Loading Orientation."
For settings displayed on the control panel, see "[Setup] Menu ([Paper Source] Options)" or "[Select Feeder] Menu."
