Installing the Paper Feeder
By installing the optional paper feeder in addition to the supplied multi-purpose tray and paper drawer, the printer can feed up to 1,600 sheets of paper continuously and automatically.
Paper Feeder Unit PF-45
<If the printer is already installed>
When installing the paper feeder in the printer after installing the printer, move the printer to an appropriate location temporarily.
"Moving the Printer"
For details on the precautions for when installing the paper feeder, see "Attention (Printer Installation)."
Remove all the orange tape if it is attached to the paper feeder when performing the following procedure.
1
Take the paper feeder out of the box.
2
Pull out the paper drawer of the paper feeder.
3
Remove the packing material as shown in the figure.
(1)
Remove the tape, and fold the protrusions of the packing material on each side.
(2)
While holding the lock release levers (A), slide the paper guides in the directions of the arrows.
(3)
Remove the packing material.
Check !
Checking if the packing materials are removed
Check that the following packing materials are completely removed.
Dispose of the left packing materials according to local regulations.
Make sure that all the orange tape is completely removed.
4
Carry the paper feeder to the installation site.
When carrying the paper feeder, hold the lift handles on both sides with both hands.
If you want to install the two paper feeders
Gently place the other paper feeder on the one already installed.
Also, match the positioning pins (A) and connector (B) when placing another paper feeder.
5
Pull out the paper drawer of the printer.
6
Carry the printer unit to the installation site.
After confirming that the covers and trays are closed, carry the printer by holding it by the lift handles from
the front side.
7
Gently place the printer on the paper feeder so that each surface of the printer is flush with the front or side surfaces of the paper feeder.
Also, match the positioning pins (A) and connector (B) when placing the printer.
8
Insert the paper drawers in the printer and paper feeder.
Push them in the printer and paper feeder firmly.
Next, perform the following procedures.
If you want to install the ROM modules, follow the procedure from Step 2 in "Installing ROM."
If you want to install the SD card, follow the procedure from Step 2 in "Installing SD Card."
If you install the printer and paper feeder at the same time
1
Connect the power cord.
2
Specifying the printer's initial settings.
Specifying a type of printer driver.
3
Load paper.
4
Connecting to a computer.
5
Install the printer driver.
6
Register the paper feeder in the printer driver.
7
Check the printing operation.
Check the operations by Test Page in Windows.
If you install the paper feeder afterward (If you are using the printer already)
1
Connect the cables and cords.
Reconnect the cables and power cords that were removed and restart the printer.
2
Load paper.
(Drawer 2*, 3*)
3
4
*Paper drawer of the paper feeder
Setting the Paper Feeder Information
After installing the paper feeder, set the paper feeder information.
The operation method to use with Windows is explained here. If you are a Macintosh user, see the "Online Manual."
1
Open the printer folder.
2
Right-click the icon for the printer, and then select [Printer properties] or [Properties] from the pop-up menu.
3
Obtain paper feeder information.
(1)
Display the [Device Settings] tab.
(2)
Click [Get Device Status].
Paper feeder information is obtained automatically.
When paper feeder information cannot be obtained automatically
Select the paper source option installed on your printer under [Paper Source Options].
» Printer Installation » Installing the Paper Feeder
08X4-024
