Checking the ROM Installation
After installing a ROM module, print Configuration Page to check if the module is installed properly.
Load Letter size paper.
Configuration Page is designed to be printed on Letter size paper.
Be sure to load Letter size paper when printing the Configuration Page.
1
Load Letter size paper in the multi-purpose tray or paper drawer.
2
Make sure that the printer is online.
If the printer is not online, press [  ] (Online).
3
Press [  ] (Utility).
4
Select [Configuration Page] using [  ] and [  ], and then press [OK].
5
Select [Yes] using [  ], and then press [OK] to print Configuration Page.
How to check the installation
Confirm that [BarDIMM] is displayed in [PCL].
If [BarDIMM] is not displayed, see "Removing ROM," remove the ROM module, and then try to install it again.
This is a sample of Configuration Page. The contents may differ from the Configuration Page printed by your printer.
» Printer Installation » Installing ROM » Checking the ROM Installation
08X4-028
