e-ManualTopSite mapHelp
Top » Printer Installation » Installing ROM
Installing ROM
08X4-026
Insert the ROM in the position shown in the following figure.
After checking the position of the ROM, perform the work.
It explains the procedure for inserting the ROM.
Insert the ROM correctly using the following procedure.
It explains the procedure for checking whether the ROM is inserted correctly.
After inserting, perform a check using the following procedure.
It explains the procedure for removing the ROM.
Use the following procedure when removing the ROM.
