When using the "Encrypted Secured Print" function whose security is reinforced for data communication and stored data
You need to install "Encrypted Secured Print Driver Add-in."
For details on the installation procedure, see "Readme.txt" in the supplied CD-ROM.
Before installing SD card
If the SD card is write-protected, release the protection, and then insert the card.
A Phillips screwdriver is required.
Have a screwdriver ready that matches the size of the screws for the slot cover.
Shut down the printer before turning it OFF.
For details on the procedure for shutting down the printer, see "Turning the Printer ON/OFF."
USB cable*
(2) Turn the computer OFF.
(3) Disconnect the cable from the printer.
LAN cable*
(4) Disconnect the cable from the printer.
Power cord
(5) Disconnect the power plug from the AC power outlet.
(6) Disconnect the cord from the printer.
Whether the cable is connected or not varies depending on your environment.
(1)
Remove the screw marked with "
(2)
Open the slot cover.
(3)
Remove the cover in the direction of the arrow.
(1)
Engage the tab of the SD card slot cover into the matching slit.
(2)
Close the cover.
(3)
Attach and fasten the screw.
If <Formatting SD Card?> does not appear in the display
Perform [Format] in [SD Card Maintenance] in the common Setup menu.
Setting after the SD card is installed
Perform the following procedure after the SD card is installed.
For details on the procedure for Macintosh, see "Setting the Printer Options."
Next, perform the following procedures.
