e-ManualTopSite mapHelp
Top » Printer Installation » Installing SD Card
Installing SD Card
08X4-02A
Insert the SD card in the position shown in the following figure.
After checking the position of the card, perform the work.
It explains the procedure for inserting the SD card.
Insert the SD card correctly using the following procedure.
It explains the procedure for checking whether the SD card is inserted correctly.
After inserting, perform a check using the following procedure.
It explains the procedure for removing the SD card.
Use the following procedure when removing the SD card.
