Some error messages may appear only when the Duplex Color Image Reader Unit-K1 is attached.
If a send job is canceled, <STOP> is printed in the Results column on the Send report.
Cause 1
Different sized originals were scanned without setting the Different Size Originals mode.
Remedy
Set the Different Size Originals mode, and then try scanning again.
Cause 2
Different sized originals were scanned in the 2-Sided Original mode without setting the Different Size Originals mode.
Remedy
Cause
Communication took longer than the preset time (64 minutes), causing an error.
Remedy 1
Reduce the resolution or divide the document into two or more parts, and then try sending the document again. (See "Setting the Resolution.")
Remedy 2
When receiving a document, ask the remote party to either reduce the resolution at which the document is scanned, or divide the document into two or more parts before sending it.
Cause 1
There is no paper.
Remedy
Load paper. (See "Loading Paper.")
Cause 2
The paper drawer is not correctly inserted into the machine.
Remedy
Insert the paper drawer properly. (See "Loading Paper.")
Cause
The document that you are sending is not placed correctly.
Remedy
Place the document properly into the feeder or on the platen glass, and try sending again.
Cause 1
Forwarding could not be performed because all of the addresses stored in the specified group destination have been deleted, or a mail box is specified as the group destination.
Remedy
Re-enter the group destination, and try sending again.
Cause 2
When transmitting to a destination stored in the Address Book, transmission could not be performed because the specified destination stored in the Address Book was deleted while the documents were waiting to be sent.
Remedy
Cause 1
The document could not be received because there was insufficient memory available.
Remedy
Delete unnecessary documents and documents with errors to make more memory available.
Cause 2
Data that contains more than 1,000 pages was received.
Remedy
This machine can print or store up to 999 pages of data in memory, but will delete any data that exceeds this limit. Ask the sender to resend the remaining pages.
Cause 3
The image data for the document to send was not found in memory when performing delayed sending or redialing.
Remedy
Scan the original and perform sending again.
Cause 4
Sending could not be performed when sending to multiple destinations because there was insufficient memory available.
Remedy 1
Remedy 2
Divide the sending operation into multiple batches instead of sending the document to all destinations at once.
Remedy 3
Lower the resolution or divide the document into two or more parts, and then try sending the document again.
Cause 1
The job was canceled.
Remedy
Perform the job again.
Cause 2
An error occurred because the main power switch was turned OFF while executing a job.
Remedy
Check whether the main power switch is turned ON, and perform the operation again, as necessary. (See "Main Power and Energy Saver Key.")
Cause
The document could not be sent because there was insufficient memory available.
Remedy 1
Remedy 2
Delete unnecessary files from the Mail Box to make more memory available. (See "Checking the Detailed Information for/Deleting a File in the Memory RX Inbox" and "Checking File Information.")
Remedy 3
If this problem occurs frequently, contact your local authorized Canon dealer.
Cause
The data capacity of the server is full or the number of files that can be saved in the root directory reached the upper limit.
Remedy
Delete unnecessary files from the file server, or create a new folder and move existing files to that folder to create room in the root directory.
Cause
The file could not be saved because a file with the same name already exists. Normally, automatic renaming is performed to append a number between 1 and 999 to the filename when a file with the same name exists, but the file could not be saved because files with the numbers 1 to 999 appended to them already exist.
Remedy
Change the filename and save the file again.
Cause
The length of the full path to the specified file (or folder) exceeds the maximum supported length.
Remedy
Change the filename so that the length of the full path is within 256 characters, or change the destination folder.
Cause
The file could not be saved because the maximum number of files that can be saved in the destination has been reached.
Remedy
Change the destination to save the file.
Cause
Storing cannot be performed because there are too many jobs waiting to be stored.
Remedy
Perform the operation again when the other jobs are complete.
Cause
The files are already locked by the other operations.
Remedy
Wait a while, and perform the operation again.
Cause 1
The specified Department ID does not exist, or the PIN has changed.
Remedy
Enter the correct Department ID or PIN using
- (numeric keys) on the control panel, and then try sending again. |
Cause 2
The Department ID or PIN was changed during the job.
Remedy
Try performing the job again with the new Department ID and PIN. If you do not know the PIN, contact your System Manager.
Cause 3
<Allow Printer Jobs with Unknown IDs> is set to 'Off'.
Remedy
Set <Allow Printer Jobs with Unknown IDs> and <Allow Remote Scan Jobs with Unknown IDs> for [Department ID Management] to 'On'. (See "Accepting Jobs with Unknown Department IDs.")
Cause
The document could not be sent because the memory is full.
Remedy 1
Wait a few moments, and then try again after the other send jobs are complete.
Remedy 2
Do not send the document to too many recipients at the same time. Send the document to a smaller number of recipients.
Cause
The memory for the image data is full.
Remedy 1
Remedy 2
Delete documents stored in the Mail Box and Fax/I-Fax Inbox. If the machine still does not operate normally, turn the main power OFF, and then back ON. (See "Main Power and Energy Saver Key.")
Cause
An error occurred when reading address information from the Address Book.
Remedy
Check the address settings. If the machine still does not operate normally, turn the main power OFF, and then back ON. (See "Main Power and Energy Saver Key.")
Cause
The send operation was interrupted because the size of the image data is larger than the maximum data size sets in [Maximum Data Size for Sending].
Remedy
Change the Maximum Data Size for Sending setting in [E-Mail/I-Fax Settings] in [Send] in [Function Settings] (Settings/Registration). Select a lower resolution, or if you are using I-Fax, decrease the number of pages containing images that you are sending each time, so that you do not exceed the Maximum Data Size for Sending limit. (See "Maximum Data Size for Send.") Depending on the destination conditions, it may be possible to divide the data.
Cause
The address book is currently being imported/exported from the Remote UI, or the machine is busy with other send related functions.
Remedy
Cause
The Mail Box and Fax/I-Fax Inbox memory is full.
Remedy
Delete files stored in the Mail Box and Fax/I-Fax Inbox. (See "Checking the Detailed Information for/Deleting a File in the Memory RX Inbox" and "Checking File Information.")
Cause
The maximum number of files is stored in the Mail Box and Fax/I-Fax Inbox.
Remedy
Cause
The document in Mail Box or Fax/I-Fax Inbox was deleted before the link to it was sent via e-mail.
Remedy
Store the necessary document in the Mail Box or Fax/I-Fax Inbox again, and then send the link again via e-mail.
Cause
The operation could not be performed because a service call message is displayed.
Remedy
Turn the main power OFF, and turn the main power ON again. If the operation still cannot be performed correctly, turn the main power switch OFF, remove the power plug from the outlet, and contact your local authorized Canon dealer. (See "Main Power and Energy Saver Key.")
Cause 1
The server is not functioning. The network is not connected. (The server may be unable to connect to the network, or it may have lost the connection.)
Remedy 1
Make sure that the server is ON, and check the destination. Check the status of the network.
Remedy 2
If WebDAV sending is based on the following conditions, enable Use Chunked Encoding with WebDAV Sending. (See "Dividing Data Into Chunks When Sending with WebDAV.")
The destination uses IIS6.0 with Windows Server 2003.
The authentication method for the WebDAV server is Digest Access Authentication.
SSL communication is performed via a proxy.
Cause 2
The IP address is not set.
Remedy
Check [TCP/IP Settings] in Network in [Preferences] (Settings/Registration). For details, see the manual provided with the imagePRESS Server.
Cause 3
You were unable to send to an SMB server (including the Advanced Box of another imageRUNNER ADVANCE series machine made accessible by SMB), because Windows (SMB) is being used to browse file servers. (See "Specifying a File Server Using the Browse Key (Windows (SMB)).")
Remedy 1
If a delayed send error occurs, close the [Browse] screen → scan and send the original again.
Remedy 2
If an error occurs when forwarding a document received by I-Fax to an SMB server, scan the printed document → send the file to the forwarding destination.
Remedy 3
You can avoid errors by using FTP or WebDAV as the protocol for sending to servers.
Cause 1
Remedy
Check that the SMTP server is operating properly. Check the status of the network.
Cause 2
The SMTP server name for the e-mail or I-fax is not correct. Alternatively, the domain name or e-mail address may not be set.
Remedy
Check the SMTP Server Name, Domain Name, and E-Mail Address in Communication Settings. (See "Common Communication Settings for E-Mail/I-Fax.")
Cause
A TCP/IP error (Socket or Select error, etc.) occurred when sending an e-mail or I-fax.
Remedy
Check that the network cables and connectors are properly connected. If the machine still does not operate normally, turn the main power OFF, and then back ON. (See "Main Power and Energy Saver Key.")
Cause
The client machine is not functioning or the network is down when device information is being delivered. The destination setting is incorrect.
Remedy
Check the client machine and network. Check the destination settings.
Cause 1
Remedy
Check [TCP/IP Settings] in [Preferences] (Settings/Registration).
Cause 2
When the machine was turned ON, an IP address was not assigned to the machine by the DHCP, RARP, or BOOTP server.
Remedy
Cause
A PDF or XPS file with a digital signature could not be sent, because a digital certificate or key pair registered in the machine is corrupt or could not be accessed.
Remedy
If you want to send a PDF or XPS file with a device signature, confirm that the device certificate is not corrupt. If the device certificate is corrupt, generate it again. (See "Digital Signatures.")
Cause
Could not send to a domain that is not registered as an allowed domain, because [Allow MDN Not via Server] is set to 'On'.
Remedy
Set [Allow MDN Not via Server] to 'Off', or register the domain as an allowed domain, and try to send again. (See "Restricting the Domains to Which E-mail/I-Fax Documents Can Be Sent.")
Cause
The certificate used to send a PDF or XPS with a digital signature has expired.
Remedy 1
Update the certificate, or use a certificate which has not expired.
Remedy 2
Set the date and time of the machine to the correct date and time. (See "Current Date and Time.")
Cause 1
Data could not be sent with WebDAV, because the WebDAV server or proxy server does not support SSL communications.
Remedy 1
Check the settings for the WebDAV server.
Remedy 2
Check the proxy server, if you are communicating via a proxy server.
Cause 2
Verification of the SSL server certificate was attempted when sending with WebDAV because [Confirm SSL Certificate for WebDAV TX] is set to 'On', but verification failed and sending could not be performed.
Remedy 1
Using the Remote UI, confirm that the CA certificate which signed the SSL server certificate of the WebDAV server is installed on your machine.
Remedy 2
Confirm that the SSL server certificate of the WebDAV server is valid.
Remedy 3
Make sure that the SSL server certificate is not a self-signed certificate.
Cause 1
The Remote Fax Server has not been started.
Remedy
Check the Remote Fax Server.
Cause 2
Remedy
Cause 3
The Remote Fax server could not be connected to because the machine could not connect to the DNS server.
Remedy 1
Check the DNS server name in [Communication Settings] in [E-Mail/I-Fax Settings] in [Function Settings] (Settings/Registration).
Remedy 2
Check that the DNS server is functioning normally.
Cause 1
The URL for the Rights Management Server is incorrect.
Remedy
Check [Rights Management Server Settings]. (See "Setting a Rights Management Server.")
Cause 2
Cannot start the Rights Management Server.
Remedy
Check the Rights Management Server.
Cause 3
Remedy
Cause 1
[Optimize PDF for Web] is set to 'On', and PDF modes that cannot be set are selected. (See "Optimizing PDF for Web.")
Remedy
Set only one of the following: Device Signature or User Signature. Alternatively, set [Optimize PDF for Web] to 'Off'.
Cause 2
[Format PDF to PDF/A] is set to 'On', and PDF modes that cannot be set are selected. (See "Formatting PDF Files to PDF/A.")
Remedy
Cancel the Apply Policy, Encrypt, and Visible Signature setting. Alternatively, set [Format PDF to PDF/A] to 'Off'.
Cause 1
A timeout error occurred while the machine was communicating with the SMTP server to send an e-mail message or send/receive an I-fax.
Remedy
Check that the SMTP server is functioning normally. Check the status of the network.
Cause 2
The SMTP server returned an error while trying to connect. The destination is incorrect. An error occurred on the server side during transmission to a file server.
Remedy
Check that SMTP is operating normally. Check the status of the network and file server. Check the settings for the destination.
Cause 3
You are trying to send a file to a destination for which you have no write permission.
Remedy
Cause 4
When the machine tried to send a file to the server, a file with the same name already existed on the server, and that file could not be overwritten.
Remedy
Change the settings on the file server to enable the file to be overwritten, or contact the server administrator.
Cause 5
When the machine tried to send a file to the server, either the folder name was incorrectly specified or the password was incorrect.
Remedy
Cause
The SMTP server name specified in Communication Settings is incorrect. The DNS server name specified in DNS Settings is incorrect. Connection to the DNS server failed.
Remedy
Check the settings for the SMTP Server Name and DNS Server Name in Communication Settings. (See "Common Communication Settings for E-Mail/I-Fax.")
Cause
The connection was interrupted due to reasons on the recipient's side before all of the pages could be sent.
Remedy
Cause 1
Unable to match the specified folder path when sending data to a file server.
Remedy
Check the destination.
Cause 2
You have no permission to access the folder/file, or the folder/file may be deleted in other operations.
Remedy
Change the settings on the file server to enable access to the folder, or contact the server administrator.
Cause 1
An incorrect user name or password was specified for the sending of a file to a file server.
Remedy
Change the user name or password.
Cause 2
An incorrect destination was specified for the sending of an e-mail message or I-fax.
Remedy
Check the e-mail or I-fax address.
Cause
You do not have access privileges for the specified directory.
Remedy
Set access privileges for the server directory, or send to a directory that you have access privileges for. Alternatively, contact your System Manager.
Cause 1
A POP (Post Office Protocol) server connection error occurred when receiving an I-fax.
Remedy
Check the settings for the POP Server in Communication Settings. (See "Common Communication Settings for E-Mail/I-Fax.")
Confirm that the POP server is functioning normally. Check the status of the network.
Cause 2
The POP server returned an error during the connection.
Remedy
Cause 3
A timeout error occurred on the server while connecting to the POP server.
Remedy
Cause
You cannot log on to the file server because the machine is printing a document sent to that server. Simultaneous connections are not possible.
Remedy
Wait for a few moments before trying to send the data again. Alternatively, stop the PServer.
Cause
Printing could not be performed because the maximum number of prints set in Department ID Management was exceeded.
Remedy
Contact your System Manager.
Cause
The received data is not in a printable file format.
Remedy
Ask the sender to change the file format and resend the data.
Cause
You have received data that cannot be processed (MIME information is incorrect).
Remedy
Check the settings, and ask the sender to resend the data.
Cause
You have received data that cannot be processed (BASE 64 or uuencode is incorrect).
Remedy
Cause
You have received data that cannot be processed (TIFF analysis error).
Remedy
Cause
You have received data that cannot be processed (image data cannot be decoded).
Remedy
Cause 1
Printing could not be performed because the Department ID and PIN for a reserved or executing printing job were deleted, or the PIN was changed.
Remedy
Try performing the job again with the new Department ID and PIN. Register the Department ID and PIN. If you do not know the PIN, contact your System Manager.
Cause 2
Device information could not be delivered because the System Manager is registered on the destination client machine but not on the host machine.
Or device information could not be delivered because the System Manager ID and System PIN registered in the client machine differs from the System Manager ID and System PIN registered in the host machine.
Remedy
Register the same System Manager ID and System PIN in both the host machine and the destination client machine, and then try delivering the device information again.
Cause
You have received data that cannot be processed (contains MIME information that is not supported).
Remedy
Cause
You have received HTML data.
Remedy
Ask the sender to use a file format other than HTML, and then resend the data.
Cause
Remedy
Cause
A DSN (Delivery Status Notification) error notification was received because of an incorrect I-fax address or destination setting, or because the data size of the sent documents exceeds the mail server capacity.
Remedy 1
Check the I-fax address or destination setting.
Remedy 2
Set Maximum Data Size for Sending so that it is less than the mail server capacity. (See "Maximum Data Size for Send.")
Remedy 3
Check the status of the mail server, DNS server, and network.
Cause
An I-fax document could not be received using SMTP because of the Receive Filter setting in Firewall Settings.
Remedy
Reset the Receive Filter setting in Firewall Settings. For details, see the manual provided with the imagePRESS Server.
Cause
DSN (Delivery Status Notification) mail was not sent because TCP/IP Settings in Network or Communication Settings in E-Mail/I-Fax Settings have not been set. Alternatively, DSN mail was not sent due to a problem with the mail server.
Remedy 1
Check the communication settings, DNS settings, and IP address settings. For details, see the manual provided with the imagePRESS Server.
Remedy 2
Check the status of the mail server and DNS server.
Cause
MDN (Mail Delivery Notification) mail was not sent because TCP/IP Settings have not been set, or due to a problem with the mail server.
Remedy 1
Check the communication settings, DNS settings, and IP address settings. For details, see the manual provided with the iimagePRESS Server.
Remedy 2
Cause
An MDN (Mail Delivery Notification) error notification was received because of an incorrect I-fax address or destination setting, or because trouble occurred in the network or mail server. Alternatively, the memory of the receiving machine is full.
Remedy
Cause
The maximum number of text lines for receiving an I-fax has been exceeded.
Remedy
Ask the sender to reduce the amount of text data in the body of the document, and then resend the data.
Cause
A connection request was received from a host whose connection is restricted by the Receive Filter settings in Firewall Settings.
Remedy
Check the Receive Filter settings in Firewall Settings. For details, see the manual provided with the imagePRESS Server.
This may also represent a hacking attempt via unauthorized access.
Cause
The user name or password specified in Communication Settings is incorrect.
Remedy
Check the user name and password set for <SMTP Authentication (SMTP AUTH)> in Communication Settings. (See "Common Communication Settings for E-Mail/I-Fax.")
Cause
An encryption algorithm that matches the mail server does not exist for sending e-mail or I-fax.
Remedy 1
Set Allow SSL to 'Off' in Communication Settings. (See "Common Communication Settings for E-Mail/I-Fax.")
Remedy 2
Add the same encryption algorithm as the mail server in the mail server settings.
Cause 1
The mail server requested authentication using the client certificate for sending an e-mail or I-fax.
Remedy 1
Remedy 2
Change the mail server settings so that a client certificate is not requested when sending.
Cause 2
Verification of the SSL server certificate was attempted when sending with SMTP because [Confirm SSL Certificate for SMTP TX] is set to 'On', but verification failed and sending could not be performed.
Remedy 1
Using the Remote UI, confirm that the CA certificate which signed the SSL server certificate of the SMTP server is installed on your machine.
Remedy 2
Confirm that the SSL server certificate of the SMTP server is valid.
Remedy 3
Cause
There is a large difference between the current time set in the KDC (Key Distribution Center) server and the time set in the machine.
Remedy 1
Adjust the current date and time in Date/Time Settings. (See "Current Date and Time.")
Remedy 2
Adjust the current time set in the KDC (Key Distribution Center) server.
Cause 1
When sending with POP before SMTP, SSL encrypted communication with the POP server failed.
Remedy 1
Check the SSL encrypted communication setting of the POP server.
Remedy 2
Set <Allow SSL (POP)> in [Communication Settings] to 'Off'. If the problem cannot be solved, set <POP Authentication Before Send> in [Communication Settings] to 'Off', and change the communication setting to the other except for the POP before SMTP. (See "Common Communication Settings for E-Mail/I-Fax.")
Cause 2
Verification of the SSL server certificate was attempted when receiving with POP because [Confirm SSL Certificate for POP RX] is set to 'On', but verification failed and receiving could not be performed.
Remedy 1
certificate of the POP server is installed on your machine.
Remedy 2
Confirm that the SSL server certificate of the POP server is valid.
Remedy 3
Cause
When sending with POP before SMTP, POP authentication (POP AUTH) failed.
Remedy 1
Check the settings of the POP address and POP password in [Communication Settings]. (See "Common Communication Settings for E-Mail/I-Fax.")
Remedy 2
Check the POP authentication setting of the POP server.
Remedy 3
Select [Standard] or [APOP] for <POP AUTH Method> in [Communication Settings]. If the problem cannot be solved, set <POP Authentication Before Send> in [Communication Settings] to 'Off', and change the communication setting to the other except for the POP before SMTP. (See "Common Communication Settings for E-Mail/I-Fax.")
Cause
When sending with POP before SMTP, POP authentication (APOP) failed.
Remedy 1
Remedy 2
Check the APOP setting of the POP server.
Remedy 3
Select [Standard] or [POP AUTH] for <POP AUTH Method> in [Communication Settings]. If the problem cannot be solved, set <POP Authentication Before Send> in [Communication Settings] to 'Off', and change the communication setting to the other except for the POP before SMTP. (See "Common Communication Settings for E-Mail/I-Fax.")
Cause
Could not save the received file in the Confidential Fax Inbox, as the memory of the Mail Box or Fax/I-Fax Inbox is full.
Remedy
Delete unnecessary files stored in the Confidential Fax Inbox or the Memory RX Inbox. (See "Checking the Detailed Information for/Deleting a File in the Memory RX Inbox.")
Cause
Device information could not be delivered because the destination client machine is executing a job.
Remedy
Deliver the device information again after the destination client machine has finished executing its job.
Cause
Device information could not be delivered because the destination client machine is operating a screen related to the device information.
Remedy
Check the device information that was not delivered, and then deliver the device information again.
Cause 1
There is insufficient memory remaining in the system.
Remedy
Check the system's available memory, and delete unnecessary files in the Mail Box and Fax/I-Fax Inbox. (See "Fax/I-Fax Inbox" and "Access Stored Files.")
Cause 2
The memory for image data is full.
Remedy
Delete unnecessary files and files with errors to make more memory available. (See "Fax/I-Fax Inbox" and "Access Stored Files.")
Cause 3
The scanned file cannot be stored because the number of files stored in the specified Mail Box or Fax/I-Fax Inbox has exceeded the upper limit.
Remedy
Delete files stored in the specified Mail Box or Fax/I-Fax Inbox. (See "Fax/I-Fax Inbox" and "Access Stored Files.")
Cause
An error occurred because the main power was turned OFF due to an unspecified cause while a job was being processed.
Remedy
Check that the power plug is firmly inserted into the power outlet, and that it is not in a state where the power can easily be turned OFF. Try processing the job again, if necessary. (See "Main Power and Energy Saver Key.")
Cause 1
The job could not be executed when you tried to print a large number of pages on the printer, due to insufficient resources.
Remedy
Reduce the number of pages to print, or execute the job again when there are no other reserved print jobs.
Cause 2
When sending print data to the machine from a computer, the job could not be executed because it was canceled from the printer driver.
Remedy
Perform the operation again.
Cause 3
The maximum received data size was exceeded when processing the received data.
Remedy
Perform printing again when all the jobs are complete. If you still cannot perform printing, check the sent data.
Cause
Device information was delivered from a machine of a different model group with [Restrict Receiving Device Information] set to 'On' in [Device Information Distribution Settings] in [Management Settings] (Settings/Registration) on the destination client machine.
Remedy
Set [Restrict Receiving Device Information] to 'Off' in [Device Information Distribution Settings] in [Management Settings] (Settings/Registration), and deliver the device information again. (See "Restricting the Reception of Device Information.")
Cause
Device information could not be delivered because it included a language that cannot be handled by the destination client machine.
Remedy
Contact your local authorized Canon dealer.
Cause
Data reception timed out or the job was canceled on the host.
Remedy
Check the network status, and perform printing again.
Cause
A problem occurred in the print data.
Remedy
Change the print data or print settings, and perform printing again.
Cause 1
A compression error occurred with the image data.
Remedy
Cause 2
An original was not scanned properly, or the orientation of the original was incorrect.
Remedy 1
Remedy 2
Turn the main power OFF, and turn the main power ON again. (See "Main Power and Energy Saver Key.")
Cause 1
A paper jam occurred during printing.
Remedy
Remove any jammed paper, and perform printing again after reloading the paper.
Cause 2
Transparency/clear/translucent film not recommended for this machine were used.
Remedy
Perform printing again using transparency/clear/translucent film recommended for this machine.
Cause 3
A print job was sent using a PDL that is not supported by the machine.
Remedy
Confirm the PDLs supported by the machine with your System Manager, and use the appropriate printer driver.
Cause 4
An unsupported combination of functions was specified.
Remedy
Change the print data resolution or other print settings, and perform printing again.
Cause
An error occurred while processing the print data or image data.
Remedy
Cause 1
The maximum number of sheets that can be saddle stitched was exceeded when printing.
Remedy
Cause 2
Remedy
Cause 3
Data not guaranteed to be compatible was printed.
Remedy
Cause
Remedy
Check the settings, and then try the operation again.
Cause
The functions related to job execution are restricted.
Remedy
Cause
Failed to communicate with the destination when sending with WebDAV, because access via a proxy server was requested (received HTTP Error 305: Use Proxy).
Remedy 1
Remedy 2
Check the proxy settings. For details, see the manual provided with theimagePRESS Server .
Cause
Received a response from the destination stating that authentication failed when sending with WebDAV (received HTTP Error 401: Unauthorized).
Remedy 1
Check the user name and password for the destination.
Remedy 2
Check the security settings of the WebDAV server.
Cause
Received a response from the destination stating that the request was denied when sending with WebDAV (received HTTP Error 403: Forbidden).
Remedy 1
Wait a few moments, and then try again.
Remedy 2
Remedy 3
Cause
Received a response from the destination stating that the specified folder could not be found when sending with WebDAV (received HTTP Error 404: Not Found/409: Conflict/410: Gone).
Remedy
Cause
Received a response from the destination stating that access is denied when sending with WebDAV (received HTTP Error 405: Method Not Allowed).
Remedy
Cause
Received a response from the destination stating that proxy authentication failed when sending with WebDAV (received HTTP Error 407: Proxy Authentication Required).
Remedy
Check the proxy settings. For details, see the manual provided with the imagePRESS Server.
Cause
Received a response from the destination stating that the connection timed out when sending with WebDAV (received HTTP Error 408: Request Timeout).
Remedy 1
Remedy 2
Cause
Received a response from the destination stating that chunked encoding was denied when sending with WebDAV (received HTTP Error 411: Length Required).
Remedy 1
Set Use Chunked Encoding with WebDAV Sending to 'Off'. (See "Dividing Data Into Chunks When Sending with WebDAV.")
Remedy 2
Cause
Received a response from the destination stating that the size of the data was too large when sending with WebDAV (received HTTP Error 413: Request Entity Too Large).
Remedy
Cause
Received a response from the destination stating that the URI (host name + folder path) was too long when sending with WebDAV (received HTTP Error 414: Request-URI Too Long).
Remedy
Cause
Received a response from the destination stating that the server encountered an unexpected condition that prevented it from executing the request when sending with WebDAV (received HTTP Error 500: Internal Server Error).
Remedy
Cause
Received a response from the destination stating that the server does not support the necessary functions to execute the request when sending with WebDAV (received HTTP Error 501: Not Implemented).
Remedy 1
Remedy 2
If you are sending via a proxy server without using SSL communication, set Use Chunked Encoding with WebDAV Sending to 'Off'. (See "Dividing Data Into Chunks When Sending with WebDAV.")
Cause
Received a response from the destination stating that the proxy server failed to communicate with the server above it when sending with WebDAV (received HTTP Error 502: Bad Gateway).
Remedy 1
Remedy 2
Check the settings of the proxy server.
Cause
Received a response from the destination stating that the server could not handle the current request when sending with WebDAV (received HTTP Error 503: Service Unavailable).
Remedy
Cause
Received a response from the destination stating that the proxy server failed to communicate with the server above it when sending with WebDAV (received HTTP Error 504: Gateway Timeout).
Remedy 1
Remedy 2
Cause
Received a response from the destination stating that the server does not support the necessary functions to execute the request when sending with WebDAV (received HTTP Error 505: HTTP Version Not Supported).
Remedy
Cause
Received a response from the destination stating that the server lacks sufficient free disk space to execute the request when sending with WebDAV (received HTTP Error 507: Insufficient Storage).
Remedy
Cause
An unexpected error occurred when sending with WebDAV.
Remedy 1
Remedy 2
Cause
Received a response from the destination stating that the request was invalid when sending with WebDAV (received HTTP Error 400: Bad Request).
Remedy
If you are sending via a proxy server without using SSL communication, Set Use Chunked Encoding with WebDAV Sending to 'Off'. (See "Dividing Data Into Chunks When Sending with WebDAV.")
Cause
The original cannot be scanned or printed because it is embedded with job restriction information.
Remedy
Check the job restriction information, or contact your System Manager.
Cause
The e-mail message or I-fax has been successfully sent, but reception may be incomplete because the transmission was relayed via multiple servers.
Check the following, as necessary.
Remedy 1
If you are using POP RX, press [Check I-Fax RX] on the Status Monitor/Cancel screen to check whether the machine has received an error notification. (See "Checking I-Fax Transmission.")
Remedy 2
If you are using POP RX and you set something other than '0 min' for [POP Interval] or set to receive error notification via SMTP, the error notification received by the machine is automatically printed. (See "Common Communication Settings for E-Mail/I-Fax.")
Remedy 3
Contact the other party.
Cause
Destinations registered in [Favorite Settings] are not updated when the Address Book is retrieved using device information delivery from an imageRUNNER/imagePRESS series machine connected to the network.
Remedy
Register [Favorite Settings] again from the touch panel display of the machine.
Cause
The job could not be executed because a network error occurred.
Remedy
Check the path length and access privileges of the server, and whether the file or folder is in use.
Cause
Printing has been canceled because the entered finishing size value for perfect binging is out of available range.
Remedy
Specify the finishing size within the available range, and restart the booklet job. (See "Perfect Binding" in "Copy" or "Perfect Binding" in "Access Stored Files.")
Cause
Printing has been canceled because the specified main document size for perfect binding is out of available range.
Remedy
Specify the main document size within the available range, and restart the booklet job. (See "Perfect Binding" in "Copy" or "Perfect Binding" in "Access Stored Files.")
Cause
Printing has been canceled because the horizontal and vertical ratio of the main document for perfect binding is out of available range.
Remedy
The available horizontal and vertical ratio of main document size is 1:1.25 to 1:1.5. Change the main document size and restart the booklet job.
Cause
Printing has been canceled because the specified cover's paper type for perfect binding is not available.
Remedy
Specify the available paper type for the cover page and restart the booklet job. For more information on the paper type, see the Instruction Manual for the Perfect Binder-E1.
Cause
Printing has been canceled because the specified cover size for perfect binding is out of available range.
Remedy
Specify the cover page size within the available range, and restart the booklet job. (See "Perfect Binding" in "Copy" or "Perfect Binding" in "Access Stored Files.")
Cause
(When using the Perfect Binding mode and trimming is set.) Printing has been canceled because the specified finishing size is not available for the main document size.
Remedy
Confirm the available combination of main document size and finishing size, and restart the booklet job. (See "Perfect Binding" in "Copy" or "Perfect Binding" in "Access Stored Files.")
Cause
Printing has been canceled because the specified cover page size is not available for the main document size when using the Perfect Binding mode.
Remedy
Confirm the available combinations of main document size and cover page size, and restart the booklet job. (See "Perfect Binding" in "Copy" or "Perfect Binding" in "Access Stored Files.")
Cause
(When using the Perfect Binding mode and trimming is set.) Printing has been canceled because the specified finishing size is not available for the cover page size.
Remedy
Confirm the available combination of cover page size and finishing size, and restart the booklet job. (See "Perfect Binding" in "Copy" or "Perfect Binding" in "Access Stored Files.")
Cause
Reserved communication jobs were cleared.
Remedy
Reserve the jobs again, if necessary.
