Common Communication Settings for E-Mail/I-Fax
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [E-Mail/I-Fax Settings].
Press [Communication Settings] → set the e-mail server.
The machine supports POP3, and can also function as an SMTP receive server.
The machine can only receive I-faxes and communication error notices.
Using the machine as an SMTP receive server:
Press [On] for <SMTP RX> → [Off] for <POP>.
Press [E-Mail Address].
Enter the e-mail address → press [OK].
Press [Authent./ Encryption] → set <Allow SSL (SMTPReceive)> → press [OK].
If you select [Always SSL] for <Allow SSL (SMTPReceive)>, only reception of data encrypted using SSL is allowed, and communications not using SSL from the host are rejected.
If you select [On] for <Allow SSL (SMTPReceive)>, receiving SSL encrypted data may only be allowed when there is a request from the host.
Even if you select [On] for <Allow SSL (SMTPReceive)>, the data will not be encrypted if the SMTP host does not support encryption.
Using a POP server to receive communications:
Press [Off] for <SMTP RX> → [On] for <POP>.
Press [POP Server].
Enter the IP address or name for the POP server → press [OK].
Press [POP Login Name].
Enter the POP login name → press [OK].
Press [POP Password].
Enter the POP password → press [OK].
Specify the time interval to automatically check the POP server in <POP Interval>.
Press [Authent./ Encryption] → set <POP AUTH Method>.
Set <Allow SSL (POP)> → press [OK].
If you want to send encrypted data, set <POP> to 'On'.
If you set less than 10 minutes (excluding '0 min') for <POP Interval>, the machine will not enter a complete Sleep mode.
Even if you select [On] for <Allow SSL (POP)>, the data will not be encrypted if the POP server does not support encryption.
Logging in to a POP server before sending (POP before SMTP):
Press [SMTP Server].
Enter the IP address or name for the SMTP server → press [OK].
Press [POP Server].
Press [On] for <POP Authentication Before Send> → [Off] for <SMTP Authentication (SMTP AUTH)>.
Set <Allow SSL (POP)> → <Allow SSL (SMTP Send)> → press [OK].
If you want to send encrypted data, set <Allow SSL (POP)> or <Allow SSL (SMTP Send)> to 'On'.
Even if you select [On] for <Allow SSL (SMTP Send)>, the data will not be encrypted if the SMTP host does not support encryption.
Logging in to an SMTP server before sending (SMTP Authentication):
Press [Authent./ Encryption] → [Off] for <POP Authentication Before Send>.
Press [On] for <SMTP Authentication (SMTP AUTH)> → [User Name].
Enter the user name for logging in to the SMTP server → press [OK].
If you are using a Microsoft SMTP server, enter the user name using the following format: user name@domain name. For more information, confirm the Microsoft SMTP server settings.
Press [Password].
Enter the password for logging in to the SMTP server → press [OK].
Set <Allow SSL (SMTP Send)> → <Display Auth. Screen When Send> → press [OK].
If you want to send encrypted data, set <Allow SSL (SMTP Send)> to 'On'.
If you want to display the authentication screen when sending, set <Display Auth. Screen When Send> to 'On'.
Sending without authenticating:
Press [Off] for <SMTP Authentication (SMTP AUTH)>.
Set <Allow SSL (SMTP Send)> → press [OK].
4.
Press [OK].
