Only LTR Tab Paper can be used.
When you load tab paper, make sure to register the paper type. (See "Registering the Paper Size and Type for a Paper Source.")
If you want to insert printed tab paper as a chapter page, insert a blank paper where the tab paper will be inserted.
Paper which has been rolled or curled must be straightened out prior to use.
Make sure that the height of the paper stack does not exceed the limit mark (
) at the back of the paper drawer. |
CAUTION |
When returning the paper drawer to its original position, be careful not to get your fingers caught, as this may result in personal injury.
Never place paper or any other items in the open part of the paper drawer next to the paper stack. Doing so may cause a paper jam.
When you are not loading tab paper, make sure to remove the Tab Feeding Attachment Kit-B1 from the paper drawer. Using the Tab Feeding Attachment Kit-B1 for storing paper other than tab paper may cause a paper jam.
