If necessary, remove all output paper in the booklet tray before replacing the staple cartridge of the saddle stitcher unit.
This procedure is necessary only if the Booklet Finisher-J1 is attached (the Booklet Finisher-J1 is an optional product).
We recommend that you order staple cases from your local authorized Canon dealer before your stock runs out.
Use only staple cases intended for use with this machine.
Remove the black part on the end before inserting the staple case.
![]() *1 Stapler Unit
*2 Saddle Stitcher Unit
Only one staple case can be inserted at a time.
When replacing the staple cases, replace both the front and back staple cases.
CAUTION |
When pushing the saddle stitcher unit back into its original position, be careful not to get your fingers caught, as this may result in personal injury.
CAUTION |
When closing the front cover of the finisher, be careful not to get your fingers caught, as this may result in personal injury.
When you have replaced the staple case, be sure to manually reposition the staples in the saddle stitcher unit. (See "Saddle Stitch Staple Repositioning.")
