CAUTION |
When handling paper, take care not to cut your hands on the edges of the paper.
Only the paper drawers can be adjusted to hold different paper sizes.
Slide the guides until they click into place. If the left guide and front guide are not aligned correctly, the paper size will not correctly appear on the touch panel display. It is also necessary to adjust the guides correctly to avoid causing a paper jam, dirty prints, or making the inside of the machine dirty.
The paper size that cannot be used depending on the model and settings is also listed on the paper size plate.
CAUTION |
When returning the paper drawer to its original position, be careful not to get your fingers caught, as this may result in personal injury.
Only LTR transparencies can be used. Make sure that the left guide is set to 'LTR' when loading transparencies in a paper drawer. If transparencies of a different size (other than LTR) are loaded in a paper drawer, the paper size and remaining amount of paper will not be detected correctly.
