Category Top
Loading Paper
Loading Paper into a Paper Drawer
Adjusting a Paper Drawer to Hold a Different Paper Size
Loading Pre-Punched Paper
Loading Transparencies
Loading Paper into the Paper Deck Unit-B2 (Optional)
Loading Tab Paper Using the Tab Feeding Attachment Kit-B1 (Optional)
Loading Envelopes Using the Envelope Feeder Attachment-D1 (Optional)
Replacing the Stamp Cartridge (Feeder)
Replacing the Staple Cartridge (For Optional Products)
Replacing the Staple Cartridge in the Stapler Unit (Staple Finisher-J1/Booklet Finisher-J1)
Replacing the Staple Case in the Saddle Stitcher Unit (Booklet Finisher-J1)
Replacing the Staple Cartridge (Inner Finisher-E1)
Removing Punch Waste (External 2/3 Hole Puncher-B2)
Replacing the Toner Cartridge
Replacing the Waste Toner Container
Routine Cleaning
Cleaning the Platen Glass and Underside of the Feeder/Platen Cover
Manual Feeder Cleaning
Automatic Feeder Cleaning
Cleaning the Inside of the Main Unit
Cleaning the Dust Proof Glass
Consumables|
You can load only LTR size transparencies.
When loading transparencies, make sure to hold only the edges of the sheets and avoid touching the print surface.
Do not load transparencies while the machine is printing. Doing so may cause a paper jam.
Use only transparencies intended for use with this machine. If you use other transparencies, you may cause damage to the machine.
It is recommended that output transparencies are immediately removed from the output tray to avoid folding of the transparencies and paper jams.
Return the remaining transparencies to their original package for storage, avoiding locations subject to high temperatures and humidity. Leaving transparencies loaded for an extended period of time may cause the sheets to stick together and result in a paper jam.
Leaving transparencies loaded for an extended period of time may cause the sheets to stick together and result in difficulties feeding the transparencies. In this case, fan the loaded transparency sheets, or if you have loaded 50 or more sheets, reduce the number of sheets to less than 50 or use new transparencies.
When printing on transparencies, depending on the type of image, the image may become dense. When this happens, adjust the density for the output image.
If a paper jam occurs, fan the loaded transparency sheets well.
