CAUTION |
Do not store paper in places exposed to open flames, as this may cause the paper to ignite, resulting in burns or a fire.
Some commercially available paper types are not suited for this machine. Contact your local authorized Canon dealer when you need to purchase paper.
To prevent moisture build-up, tightly wrap any remaining paper in its original package for storage.
For high-quality printouts, use paper recommended by Canon.
Product Name
Supported Canon Genuine Toner
imageRUNNER ADVANCE C5255/C5250
Canon GPR-30 Black Toner
Canon GPR-30 Cyan Toner
Canon GPR-30 Magenta Toner
Canon GPR-30 Yellow Toner
imageRUNNER ADVANCE C5240/C5235
Canon GPR-31 Black Toner
Canon GPR-31 Cyan Toner
Canon GPR-31 Magenta Toner
Canon GPR-31 Yellow Toner
WARNING |
Do not burn or throw used toner cartridges into open flames, as this may cause the toner remaining inside the cartridges to ignite, resulting in burns or a fire.
Do not store toner cartridges in places exposed to open flames, as this may cause the toner to ignite, resulting in burns or a fire.
If you accidentally spill or scatter toner, carefully gather the toner particles together or wipe them up with a soft, damp cloth in a way that prevents inhalation. Never use a vacuum cleaner that does not have safeguards against dust explosions to clean up spilled toner. Doing so may cause a malfunction in the vacuum cleaner, or result in a dust explosion due to static discharge.
CAUTION |
Keep toner out of the reach of small children. If toner is ingested, consult a physician immediately.
Store toner cartridges in a cool location, away from direct sunlight. (The recommended storage conditions are temperatures below 86°F and humidity below 80%.)
[Be careful of counterfeit toners]
Please be aware that there are counterfeit Canon toners in the marketplace. Use of counterfeit toner may result in poor print quality or machine performance. Canon is not responsible for any malfunction, accident or damage caused by the use of counterfeit toner. For more information, see http://www.canon.com/counterfeit. |
Finisher
Staple Cartridge
Name
Shape
Booklet Finisher-J1
Canon Staple Cartridge-D2
Canon Staple Cartridge-D3
Staple Finisher-J1
Booklet Finisher-J1
Inner Finisher-E1
Canon Staple-J1
