Setting Up a Computer for Printing
06RH-1XA
After you have completed the machine protocol settings, install the printer driver on the Macintosh that will do the printing, and then make the settings for the print destination.
If you want to use a PS printer driver provided by Apple Inc. with the Mac OS (Mac OS 9/OS X 10.3.9 or later)
1. Installation of the PPD file
2. Print settings
Set the machine as the print destination.
3. Selection of the printer name
In the Macintosh printer screen, select the printer to which the print mode you want to use is applied. The name of the printer is displayed in the Macintosh printer screen as follows ("xxx" indicates the name of the printer entered in [Service Name] in
"Protocol Settings.")
[xxx_D]: the print job is printed without spooling to the hard disk of the machine.
[xxx_S]: the print job is printed after it has been spooled to the hard disk of the machine.
