Depending on the machine you are using, you may have to use optional equipment to print via an AppleTalk network. For the equipment needed, see "Optional Equipment and System Requirements."
It is recommended that you consult the administrator for the network you are using when performing the settings in step 2.
If you are using the imagePASS or the ColorPASS, see the manual provided with the imagePASS or the ColorPASS.
If you are using the imagePASS or the ColorPASS, some functions are not available with this machine. For details, see the manual provided with the imagePASS or the ColorPASS.
