Inner Finisher-D1
Inner 2Way Tray-H1
Staple Finisher-G1, Booklet Finisher-G1
Collate
Rotate+Collate
Rotate+Group
Offset+Collate
Offset+Group
Staple+Collate
Staple+Group
A large print job may be automatically canceled by the machine. The maximum number of pages that can be printed at one time is approximately 8,000 pages. However, this number may be fewer than 8,000 if other functions (such as registering a form) are in use, or other jobs are being processed.
[Rotate+Collate] and [Rotate+Group] are available if the paper size is A4, A4R, B5, B5R, LTR, or LTRR.
If you select [Rotate+Collate] or [Rotate+Group], part of the print image may be cut off when the image is rotated. You need to load the same size paper as the original in the paper drawers in both landscape and portrait positions. If you do not, all the sheets will be printed in the orientation that the loaded paper is in.
[Offset+Collate] and [Offset+Group] are available if you select the following paper size.
When the Staple finisher or Booklet Finisher is attached: A3, B4, A4, A4R, B5, 11"x17", LGL, LTR, LTRR
When you are stapling paper in landscape orientation, the image orientation and the staple position may not match.
Corner (Upper-Left)
Double (Top)
Corner (Upper-Right)
Double (Right)
Corner (Lower-Right)
Double (Bottom)
Corner (Lower-Left)
Double (Left)
11" x 17"
LGL
LTR
LTRR
EXEC
A3
B4
A4
A4R
B5
The maximum number of sheets of plain or heavy type paper that can be stapled at one time is:
A3, B4, A4R, 11" × 17", LGL, LTRR: 30 sheets
A4, B5, LTR, EXEC: 50 sheets
Make sure to select compatible settings when using Staple and Punch simultaneously. If conflicting settings are selected, such as the staple setting for the right side of the paper and the punch setting for the left, the printer will use neither Staple nor Punch.
This function is available for selection if the External 2 Hole Puncher-B2 is attached to the Staple Finisher-G1 or Booklet Finisher-G1.
