On
Please note that the memory of the machine can store up to 8,000 pages. When you send a secured
document to be stored in the memory to be printed at a later time, and the memory is full (already
reached its maximum capacity), your document will not be stored. The memory may be full because the machine is being used for other functions (such as storing a document in an inbox or storing a form) or other jobs, which use memory space.
This function can only be selected if the Booklet Finisher-G1 is attached to the machine.
This function is not available if 'Booklet' is set to [Off].
If the print job contains only one sheet of paper, the paper will be folded but not stapled.
The number of copies of a saddle stitched booklet that can be made at one time is limited as shown below:
Number of sheets in
each booklet |
Max. number of copies
that can be printed |
1 - 16 (16 lb bond to 21 lb bond (60 g/m2 to 81 g/m2))
1 - 10 (22 lb bond to 28 lb bond (82 g/m2 to 105 g/m2))
15 (16 lb bond to 21 lb bond (60 g/m2 to 81 g/m2))
