Only Administrator can initialize the hard disk. Contact the Administrator to execute this procedure.
The font or macros information downloaded to the hard disk is deleted by initializing the hard disk.
Do not turn OFF the power when the hard disk is initializing. Doing so may damage the machine.
The hard disk cannot be initialized in the following conditions:
When print data is being received or printed. (It is recommended that you remove the cable connecting the machine to the hub, so it does not receive print data.)
When fonts are being installed or uninstalled.
The steps explained below are for initializing the PCL Hard Disk partition.
To initialize the PS Hard Disk partition, follow the same steps, except that for step 4, select [Initialize PS Hard Disk].
(Settings/Registration).
Do not turn OFF the power until the Processing/Data indicator goes out. Doing so may damage the machine.
If the following screen appears after pressing [Yes], the hard disk has not been initialized. Check whether print data is received and retry.
