Category
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Combinations and Names of Printer Kit Options
Category Top
Printing Functions
[Page Setup] Sheet
[Finishing] Sheet
[Paper Source] Sheet
[Quality] Sheet
Common Functions
[Device Settings] Sheet
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided Printing and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Booklet Printing
Using [Presets] for Printing
Printing Flow With This Machine
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Symbol Set
Custom Paper
Unit of Measure
X dimension
Y dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Collapse all|Expand all
Combinations with options (system configurations) for using the machine as a printer are available as described below.
In this manual, the combinations are each defined with the terms UFR II Printer, PCL Printer, PS Printer, PDF Direct Print Printer, and XPS Direct Print Printer.
To enable these modes and functions, you must register the license key with the machine. For information on registering the license key, see "Security."
UFR II Printer
UFR II printing is standard with the imageRUNNER ADVANCE 4051/4045/4035/4025.
Machine Model
Required Option Kit
imageRUNNER ADVANCE
4051/4045/4035/4025
(UFR II Printer Kit is Standard.)
PCL Printer
The PCL Printer Kit must be activated for PCL printing.
Machine Model
Required Option Kit
imageRUNNER ADVANCE
4051/4045/4035/4025
PCL Printer Kit
PS Printer
The PS Printer Kit must be activated for PS printing.
Machine Model
Required Option Kit
imageRUNNER ADVANCE
4051/4045/4035/4025
PS Printer Kit
The Direct Print Kit (for PDF/XPS) must be activated for PDF Direct printing.
Machine Model
Required Option Kit
imageRUNNER ADVANCE
4051/4045/4035/4025
The Direct Print Kit (for PDF/XPS) must be activated for XPS Direct printing.
Machine Model
Required Option Kit
imageRUNNER ADVANCE
4051/4045/4035/4025
