The function is not available if 'Resolution' is set to [1200 dpi].
The results of image refinement may be different depending on the types of characters and graphics you want to print.
This setting is applicable only when 'Resolution' is set to [1200 dpi].
This setting remains in effect even when the printer job is sent to a box.
This setting is also available when 'Line Refinement' is set to [On] in the printer driver.
With this setting, horizontal lines are based on the direction in which the paper is fed.
Selecting [Level 2] or higher for this setting may result in abrupt changes in gradation with halftone images.
With this setting, vertical lines are based on the direction in which the paper is fed.
If you select [1200 dpi] for [Resolution], you cannot specify the following settings: rotate collate, different paper sizes (LTR/LGL), and double stapling on the short edge of A4 and LTR size paper.
