» Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Transparency Interleaving
[Off]*, [Blank], [Printed]
If you are printing on transparencies, you can use this setting to output a sheet of paper after each transparency. The paper can be blank, or it can be a paper copy of the transparency.
[Off]
No sheets are interleaved with the transparencies.
[Blank]
A blank sheet of paper is inserted between each transparency.
[Printed]
A printed paper from the print job is inserted between each transparency.
This mode is available only if you set [Copy Set Numbering] to [Off].
When printing multiple copies, [Offset+Group] for [Finishing] cannot be used.
If the Finishing mode are specified as [Rotate+Group], [Offset+Group], and [Staple+Group], then [Rotate+Collate], [Offset+Collate], and [Staple+Collate] are specified.
If you select [Printed], the paper printouts are included in the Prints count. However, if you select [Blank], they are not included in the Prints count.
