In case C, the Import All function may not be enabled according to the model for importing. For more information, contact your local authorized Canon dealer.
In the following cases, even if you use the Import All function, the settings information may not be imported, or the value may be changed into the closest value.
There are no optional products or functions that use the set value.
The set value is not valid.
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Settings
Paper Size Group for Auto Recog. in Drawer
A5R/STMTR Paper Selection
Register Favorite Paper (Multi-Purpose Tray)
Multi-Purpose Tray Defaults
Register Custom Size
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Display Fax Function
Store Location Display Settings
Switch Language/Keyboard
Use Keyboard Shift Lock Feature
Display Remaining Paper Message
No. of Copies/Job Duration Status
Notify to Clean Original Scanning Area
Paper Type Selection Screen Priority
Switch Millimeter/Inch Entry
ID/User Name Display On/Off
Display Remaining Toner Error Message
IP Address Display Settings
Setting Information
Case A
Case B
Case C
Preferences
Timer/Energy Settings
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Auto Reset Time
Restrict Auto Reset Time
Function After Auto Reset
Auto Sleep Time
Sleep Mode Energy Use
Auto Sleep Weekly Timer
Sleep Mode Exit Time Settings
Setting Information
Case A
Case B
Case C
Preferences
Network
Confirm Network Connection Set. Changes
TCP/IP Settings
IPv4 Settings
Use IPv4
IP Address Settings
IP Address
Subnet Mask
Gateway Address
DHCP
Auto IP
DHCP Option Settings
IPv6 Settings
Use IPv6
Stateless Address Settings
Manual Address Settings
Use DHCPv6
Only Retrieve Stateful Address Prefix
DNS Settings
DNS Server Address Settings
DNS Host/Domain Name Settings
DNS Dynamic Update Settings
mDNS SettingsUse mDNS/mDNS Name
Computer Name/Workgroup Name Settings
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
Use UTF-8 to Display Name of FTP Print Job
WSD Settings
Use FTP PASV Mode
IPP Print Settings
Multicast Discovery Settings
Use HTTP
Proxy Settings
Confirm Dept. ID PIN
IPSec Settings
AppleTalk Settings
SNMP Settings
Format Host Resources MIB to RFC2790
Dedicated Port Settings
Use Spool Function
Waiting Time for Connection at Startup
Ethernet Driver Settings
IEEE 802.1X Settings
Firewall Settings
Setting Information
Case A
Case B
Case C
Preferences
External Interface
USB Settings
Accessibility
Key Repetition Settings
Reversed Display (Color)
Adjustment/Maintenance
Adjust Image Quality
Correct Density
Full Color Printing Vividness Settings
Fine Adjust Zoom
Adjust Toner Volume Used for Color Printing
Fill Area Image Adjustment Mode
Adjust Action
Time Until Stapling Starts in Stapler Mode
Setting Information
Case A
Case B
Case C
Function Settings
Common
Paper Feed Settings
Paper Drawer Auto Selection On/Off
Switch Feed Method
Suspended Job Timeout
Paper Output Settings
Output Tray Settings*
Use Optional Output Tray
Offset Jobs
Job Separator Between Jobs
Job Separator Between Copies
Print Settings
Print Priority
Text/Photo Prty. When Recog as B&W by ACS
Output Report Default Settings
Register Characters for Page No./Watermark
Copy Set Numbering Option Settings
Secure Watermark/Document Scan Lock
Forced Secure Watermark/Document Scan Lock
Printer Driver Secure Watermark
Adjust Background/Character Contrast
Relative Contrast
Standard Value Set.
Latent Area Density
Adjust TL Code
Dot Size
Dot Density
Scan Settings
Feeder Jam Recovery Method
Scanner Noise Settings
LTRR/STMT Original Selection
Remote Scan Gamma Value
Auto Online
Auto Offline
Generate File
Image Quality Level for Compact
OCR (Text Searchable) Settings
Trace & Smooth Settings
OOXML Settings
Include Background Images in Word File
Specify Minimum PDF Version
Format PDF to PDF/A
Optimize PDF for Web
256-bit AES Settings for Encrypted PDF
Rights Management Server Settings
Document Scan Lock Operational Settings
Set Authentication Method
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Auto Collate
Auto Recognize Original Orientation
Select Color Settings for Copy
Send
Common Settings
E-Mail/I-Fax Settings
Register Unit Name
Communication Settings
E-Mail Address
SMTP Server
POP Server
POP Login Name
POP Password
POP Interval
Allow SSL
Authentication Settings
Confirm SSL Certificate for SMTP TX
Confirm SSL Certificate for POP RX
Maximum Data Size for Sending
Default Subject
Specify Authentication User Dest. to Reply
Set Authentication User Destination to Sender
Allow Unregistered Users to Send E-Mail
Full Mode TX Timeout
Print MDN/DSN upon Receipt
Use Send via Server
Allow MDN Not via Server
Restrict TX Destination Domain
Auto Complete for Entering E-Mail Addresses
Fax Settings
Default Screen
Change Default Settings
Register Options Shortcuts
Register Sender Name (TTI)
Use Auth. User Name as Sender Name
ECM TX
Set Pause Time
Auto Redial
Check Dial Tone Before Sending
Fax TX Report
Fax Activity Report
Set Line
Line 1 to Line 2
Register Unit Telephone Number
Register Unit Name
Select Line Type
Edit Line Name for Select Line Screen
Default Address List When Selecting Line
Select TX Line
TX Start Speed
PIN Code Access
Confirm Entered Fax Number
Allow Fax Driver TX
Confirm Before Sending When Fax Dest. Incl.
Restrict Seq. Broadcast When Fax Dest. Incl.
Remote Fax TX Settings
Receive/Forward
Common Settings
Print on Both Sides
Select Drawer
Reduce Fax RX Size
2 on 1 Log
Print RX Page Footer
Interrupt and Print RX Jobs
Handle Files with Forwarding Errors
Set Fax/I-Fax Inbox
Always Send Notice for RX Errors
Fax Settings
Store/Access Files
Common Settings
Limit Box PIN to 7 Digits/Restrict Access
Mail Box Settings
Box Security Settings
Network Settings
Memory Media Settings
Secure Print
Simple Authentication Settings
Only Allow Encrypted Print Jobs
Setting Information
Case A
Case B
Case C
Set Destination
Change Default Display of Address Book
Address Book PIN
Manage Address Book Access Numbers
Include Pswd. When Exporting Address Book
Register LDAP Server
Auto Search When Using LDAP Server
Register/Edit LDAP Search Conditions
Acquire Remote Address Book
Acquire Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Setting Information
Case A
Case B
Case C
Management Settings
User Management
Authentication Management
Device Management
Device Information Settings
Device Information Distribution Settings
Register Destinations
Set Auto Distribution
Restrict Receiving Device Information
Restrict Receiving for Each Function
Report Settings
Set MEAP Authentication
Use MEAP Auth. When Receive
Display Job Status Before Authentication
Restrict Access to Other User Jobs
Display Job Log
Save Audit Log
Audit Log Collection*
Store Key Operation Log
License/Other
Message Board/Support Link
Remote Operation Settings
Use ACCESS MANAGEMENT SYSTEM
Data Management
Import/Export
Restrict Import/Export from Web Service
Back Up/Restore Settings*
Backup Location Settings
Auto Backup Settings
Delete Existing Data Settings
Security Settings
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Common Settings
Set Fax/I-Fax Inbox
Set/Register Confidential Fax Inboxes
Memory RX Inbox PIN
Store/Access Files
Mail Box Settings
Set/Register Mail Boxes
Setting Information
Case A
Case B
Case C
Management Settings
User Management
System Manager/Contact Person Information Settings
Department ID Management
Register PIN
Setting Information
Key Pair
Key Pair (Device Certificate)
*1
Only algorithms that can be imported with the Remote UI are supported by batch importing.
*2
The key pair is exported in the PKCS#12 format.
Setting Information
CA Certificate
Certificate Revocation List (CRL)
*1
*2
Setting Information
Case A
Case B
Case C
Main Menu Settings
Setting File
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Register/Edit Favorite Settings
Send
Common Settings
Fax Settings
Store/Access Files
Common Settings
Copy Basic Features Screen
Color Balance (Options)
Access Stored Files
Mail Box (Print)
Setting Information
Case A
Case B
Case C
Set Destination
Rename Address List
Register One-Touch
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Common Settings
Setting Information
Case A
Case B
Case C
Quick Menu Settings
Button File
Setting Information
Flow Data File
Operating Setting File
When the user management settings of an Advanced Box are imported, they are imported as authentication user management settings.
Setting Information
User Management
Role Management
Group Management
System Managment Service
Application Authentication Information
Setting Information
MEAP User Setting Information
Password information used for encrypted PDF
User name and password information used for SMTP Authentication
User name and password information used for the Rights Management Server
User name and password used for LDAP server authentication
User name and password used for File TX/Browsing authentication
User name and password used for the Personal Folder authentication
Setting Information
Case A
Case B
Case C
MEAP Application Setting Information
Data
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Type Management Settings
Setting Information
Case A
Case B
Case C
Web Access Settings
Favorites
Settings
If favorites are registered as the shortcut buttons or [Default Screen after Startup/Restoration] settings in the target machine for importing, the registered information is changed when importing the setting information of Web Access settings.
