Top » Remote UI » Audit Log Management
0R9W-1UU
This function enables you to collect/manage the logs stored in the machine with the Remote UI. The administrator can check the collected logs to survey how the machine is being used.
Types of Logs
This function can manage the following logs:
User Authentication Log
This log contains information related to the authentication status of user authentication, and the registering/changing/deleting of user information.
Login/Logout Log
User Authentication Success/Failure Log
Log for the registering/changing of user information managed by User Authentication
Log for Role Management (adding/setting/deleting) by ACCESS MANAGEMENT SYSTEM
Job Log
This log contains information related to the completion of copy/fax/scan/send/print jobs.
Mail Box Document Operation Log
This log contains information related to the operations performed on data in the Mail Box, the Memory RX Inbox, and the Confidential Fax Inbox.
Mail Box Authentication Log
This log contains information related to the authentication status of the Mail Box, the Memory RX Inbox, and the Confidential Fax Inbox.
Mail Box Backup Log
This log contains information related to the backup of the data in the Mail Box, the Memory RX Inbox, and the Confidential Fax Inbox.
Advanced Box Operation Log
This log contains information related to the operations performed on file to the Advanced Box, the Network (Advanced Box of other machines), and the Memory Media.
Network Connection Log
This log contains information regarded to IPSec communication failures.
Machine Management Log
This log contains information related to the starting/shutting down of the machine and the following management operations:
When (Settings/Registration) is pressed to change the machine settings
When the Device Information Delivery Settings mode is used to change the machine settings
When the time of the machine is set/changed
Export/Import All Log
This log contains information related to importing/exporting the settings with Export/Import All. (See "Import/Export Function.")
MEAP Application Management Log
This log contains information related to the installing/starting/stopping of the MEAP application and the license operation.
Registering/Updating the Software Log
This log contains information related to the manual/delivered installation of MEAP application and system options, manual/delivered update of the firmware, and the settings for the firmware delivery.
Log for Audit Log Management
This log contains information related to the exporting/deleting of logs with this function.
Managing Logs
You can use the Remote UI to manage the logs collected from the machine.
Please note that Canon will not be held responsible for any damages caused by the use of Audit Log Management or the inability to use Audit Log Management.
The maximum number of logs that can be managed with this function is 40,000, regardless of the type of log. When this maximum number is reached, the oldest logs are erased and overwritten with the new logs.
If Sleep Mode Energy Use is set to [High], logs are not collected when the machine enters the Sleep mode.
The logs described in this section may be collected multiple times by the machine's system processes during user operations.
This operation can only be performed by a user with the required privileges. For more information, see "Setting Administrators."
The collected logs and exported logs include items for the Date and Time, User Name, Operation Type, and Result (OK/NG). Job logs also include items related to the job type.
To generate a Network Connection Log, Mail Box Authentication Log, Mail Box Document Operation Log, Machine Management Log, select [Save Audit Log] for [Save Audit Log] in [Device Management] in [Management Settings] (Settings/Registration) → click [OK].
Starting/Stopping Log Collection
You can start or stop log collection. The collected logs are saved as a single audit log file.
Click [Settings/Registration] → [Device Management] → [Export/Clear Audit Log] → [Start] for <Audit Log Collection>.
The saved logs may not be displayed in the order that they are collected.
Log collection is stopped by default.
If you start or stop log collection, this setting is retained until it is changed. The setting does not change when the machine is restarted.
If you stop log collection while logs are being collected, the logs for the period that log collection was stopped are not collected when log collection is next started.
Checking the Number of Saved Logs and the Date/Time They Were Collected/Saved
You can check the number of logs collected from the machine that are saved, and the date/time that they were collected/saved.
Click [Settings/Registration] → [Device Management] → [Export/Clear Audit Log] → [Audit Log Information].
Current Number of Saved Logs:
Displays the number of logs that are currently saved.
Logs Last Collected On:
Displays the date/time that a log was last collected from the machine.
Logs Last Saved On:
Displays the date/time that a log collected from the machine was last saved.
Exporting Collected Logs
You can save the various logs collected from the machine all together to a computer in the CSV format.
The log type numbers indicated in the logs to be exported correspond to the following log types:
4098
1001/8193
Job Log
8197
8199
8202
8203
Mail Box Backup Log
8200
8198
3001
8196
Advanced Box Save Log
3101
3101/8206
Click [Settings/Registration] → [Device Management] → [Export/Clear Audit Log].
Click [Export] for <Export Audit Logs>.
To automatically delete the logs after they are exported, select [Delete logs from device after export].
If you select [Delete logs from device after export], make sure to select [Store] after clicking [Export]. If you select [Cancel], the logs will be deleted without being saved.
Follow the instructions on the screen to specify the location where you want to save the file.
To export the various logs collected from the machine, use SSL or IPSec. To use SSL, set [Use SSL] to 'On' in [Remote UI] in [Management Settings] (Settings/Registration). If you want to use IPSec, see "IPSec Settings."
Log collection is stopped while the export process is being performed.
If the display language setting of the machine is different from when the logs were collected, the file may contain garbled characters when the logs are exported.
Deleting Collected Logs
You can delete all the logs collected from the machine.
Click [Delete] for <Delete Audit Logs>.
Click [OK].
When an Error is Displayed
If the audit log collection function is enabled and an error occurs in the hard disk, the message <Could not retrieve audit log due to an error.> is displayed on the touch panel display.
If this happens and you access [Export/Clear Audit Log] from the Remote UI, the message <Management area of audit logs may have been corrupted because an error occurred. The system will be initialized.> is displayed.
Click [Initialize] to perform initialization.
If initialization is performed, log collection is stopped and all the logs that have been collected are deleted. To continue collecting logs, start log collection again.
