Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Printing the TX Report
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying Destinations » Specifying Destinations Using the Address Book (Remote)
0R9W-0YE
You can specify a destination by searching the Address Book of the server machine (another imageRUNNER ADVANCE series machine that has the server function) from the client machine (this machine) that is connected via the network. The Address Book of the server machine that can be accessed via the network is called the Remote Address Book.
To use the Remote Address Book, it is necessary to configure the settings for [Acquire Remote Address Book]. (See "Obtaining the Remote Address Book.")
To use the Remote Address Book, it is necessary to configure the server machine settings. Set to open the Remote Address Book externally on the server machine. See the user manuals for imageRUNNER ADVANCE series machines that have a server function.
You can also browse destinations registered in the one-touch buttons of a server machine from a client machine on the network. (See "Specifying Destinations Using the One-Touch Buttons.")
Press [Scan and Send] → [Address Book].
Press [Change Address Book].
[Change Address Book] only appears if you register both the Remote Address Book and LDAP server. If only the Remote Address Book is registered on the machine, [To Remote Add. Book] is displayed.
Press [Remote].
4.
Select the destination → press [OK].
You can select multiple destinations.
For instructions on searching for registered destinations, see "Address Book Screen."
If you select a destination that is stored with an access number, press [Regist./Other] → [Access No.] → enter the access number using - (numeric keys). If you press [Addresses without Access Number], the destinations that are not managed with an access number are displayed.
To cancel a selected destination, select the destination again.
If the server machine is performing the system manager information settings, authentication between the server machine and the client machine is performed while the client machine obtaining the remote address.
Authentication is performed by matching the System Manager ID and System Manager PIN set by the server machine and client machine.
The availability of the Remote Address Book depends on the status of the system manager information settings for the server machine and client machine, as shown below.
When the server machine is performing the system manager information settings
When the client machine is performing the system manager information settings
The System Manager ID and System Manager PIN for the server machine and client machine match
Can use the Remote Address Book
Performing
Performing
Matches
Yes
Does Not Match
No
Not Performing
No
Not Performing
Performing
Yes
Not Performing
Yes
For instructions on setting the System Manager ID and System Manager PIN, see "Specifying the System Manager Settings."
Up to eight machines including this machine can be connected as client machines at the same time to the server machine with the Remote Address Book that is opened externally. However, if the server machine is performing other network communication during this time, the number of machines that can connect may be reduced. If the machine cannot connect, a network error notice is sent.
If an authentication error or a communication timeout due to network congestion occurs between the client and server, you cannot obtain the destination from a Remote Address Book. You can set the communication timeout in [Communication Timeout] in [Acquire Remote Address Book]. (See "Obtaining the Remote Address Book.")
