Setting the Memory Lock Mode
07SE-10F
You can set to store received I-fax documents in the Memory RX Inbox without printing them. You can later check the received documents in the Memory RX Inbox, and print or send them as necessary.
If you set [Use I-Fax Memory Lock] to 'On', you can set <I-Fax Memory Lock> for the Memory RX Inbox to 'On' or 'Off' as necessary. (See
"Specifying the Fax/I-Fax Inbox Settings" and
"Receiving Files Through Fax or I-Fax.")
You cannot store received documents in the Memory RX Inbox in the following cases. (These numbers may vary depending on the remaining capacity of memory.)
When a total of 1,500 documents have been stored in the Fax/I-Fax Inbox
When a total of 6,000 pages have been stored in the Fax/I-Fax Inbox
