Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Storing New Addresses
07SE-0XH
You can store a destination in the Local Address Book or a one-touch button to save the effort of entering that destination's address each time you send a job. This also enables you to retrieve the destination from the Local Address Book or one-touch button when specifying various settings.
Regarding the Local Address Book
The Local Address Book is a feature you can use to store fax, e-mail, I-fax, and file server destinations. The Address Book is divided into 10 Address Lists and one-touch buttons. You can store up to 1,800 destinations, including 1,600 destinations in the Address Lists (1 to 10), and 200 destinations in one-touch buttons.
By storing your own e-mail address, you can easily specify it as a reply-to e-mail address, and use the Job Done Notice function.
Each address entry is treated as a single entry. If you register a given e-mail address in a group address, that e-mail address and the group address are counted as two separate entries.
The Local Address Book data can be saved and imported using the Remote UI. (See "Loading Settings Information (Import Individually).")
If you want to manage destinations with the Manage Address Book Access Number mode, set [Manage Address Book Access Numbers] to 'On'. (See "Managing the Address Book with Access Numbers.")
If a required destination setting has not been set after registering the access number, the screen for specifying the destination settings appears again.
You can enter up to seven digits for the access number. If you enter fewer than seven digits, the machine stores the access number with leading zeros.
Example: If <321> is entered, <0000321> is stored.
You cannot store an access number with only zeros as the number, such as <0000000>. If you enter a number that begins in zeros, such as <02> or <002>, the zeros are ignored and the number is registered as <0000002>, the same as if you had simply entered <2>.
For instructions on registering, editing, or deleting a fax number in a one-touch button, see "Storing New Addresses."
You can store destinations on the Log screen for [Send] on the Status Monitor/Cancel screen. (See "Checking and Canceling Send Jobs.")
