[On]:
Received files are stored in the Memory RX Inbox.
[Off]:
Received files are printed automatically.
If you have set [Memory Lock Start Time]/[Memory Lock End Time] in [Set Fax/I-Fax Inbox], the following is displayed.(See "Specifying the Fax/I-Fax Inbox Settings.")
When you select [On] for <Fax Memory Lock>/<I-Fax Memory Lock>: The end time for Memory Lock is displayed.
When you select [Off] for <Fax Memory Lock>/<I-Fax Memory Lock>: The start time for Memory Lock is displayed.
If you set <Fax Memory Lock> and/or <I-Fax Memory Lock> to 'Off', files received through the Fax/I-Fax function are automatically printed and deleted from the Memory RX Inbox.
