Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » What This Machine Can Do
07SE-0WJ
Equipped with features to meet the needs of document work in a digitized office, the imageRUNNER ADVANCE C2230/C2225 represents the ultimate in digital color multitasking machines.
Various Sending Methods
You can easily scan paper documents and send them to one or multiple recipients via e-mail or I-fax. This enables increased workplace efficiency in the area of document exchange. You can also send documents to FTP, SMB, and WebDAV file servers, which helps to digitize paper documents for convenient data access and management.
File Formats for Every Need
You can send documents in a variety of file formats, including PDF, XPS, OOXML(pptx), JPEG, and TIFF. This gives you the freedom to send documents in the manner best suited to the purpose of the document, as well as the recipient's document handling environment.
Flexible Scan Features
This machine offers a variety of convenient scanning features, such as scanning 2-sided and book originals, and the ability to merge and send documents scanned separately. You can also set the exposure, color mode, and scan size to match the type of original that you are scanning. In addition, you can store preferred scan settings and retrieve them at any time.
Preview Function
You can use the preview function to check scanned images and preventing mistakes before sending.
Search for Destination via Remote Address Book
The machine can access a server machine on the network as a client machine to search for/specify destinations from the Address Book of the server machine.
Address Search with LDAP Server
You can search for a destination from the directory listings on the network using LDAP (Lightweight Directory Access Protocol) servers. You can then specify the address as a destination, or register it in the address book.
Receiving I-Faxes in Memory (See "Receiving Files Through Fax or I-Fax.")
You can store received I-fax documents in the Memory RX Inbox instead of printing them. You can then check the sender information and the number of pages that each document contains before printing it or forwarding it to another destination.
Automatic Forwarding
You can set to automatically forward received I-fax documents that match specified forwarding conditions to any destination using the desired send settings. You can forward received I-fax documents to another machine (relay function), or store them in a Confidential Fax Inbox. You can also set automatic forwarding to activate at a specified time. Since received documents that do not match the forwarding conditions can also be forwarded to any desired destination, you can use this function to sort and deliver received I-fax documents to the appropriate destinations. (See "Storing Forwarding Settings.")
