Storing in an Advanced Box
You can store scanned documents in the Advanced Box of another imageRUNNER ADVANCE series machine opened as an SMB server or WebDAV server. The stored files can be access from a computer for viewing or editing.
For more information on Advanced Boxes, see user manuals for other imageRUNNER ADVANCE series machines with Advanced Boxes.
For information on whether you can specify the destination imageRUNNER ADVANCE series machine using a host name, consult your system administrator.
Press [Scan and Send] → [New Destination].
Press [File].
Press the drop-down list → select the desired server protocol.
Select [Windows (SMB)] or [WebDAV].
To save files in the Advanced Box of another imageRUNNER ADVANCE machine with an imagePASS attached, select [WebDAV]. (Windows (SMB) cannot be used.)
4.
Specify each setting.
If you select [Windows (SMB)] for the protocol:
Item
Description
Host Name
A host name is a name assigned to a host computer that provides services on the network. A specific host name is assigned to each host computer to identify it on the Internet. Here, enter the IP address or host name of the destination imageRUNNER ADVANCE series machine plus "\share" or "\users". Example: To save to the Shared Space: \\192.168.100.50\share
To save to the Personal Space: \\192.168.100.50\users
Folder Path
A folder path is a series of characters that signify the location of the folder. Here, specify which folder under the Shared Space (share) or Personal Space (users) to save the document to. Example: \folder (To send to the [folder] folder in the Shared Space)
User Name
The login user name registered in the destination Advanced Box.
Password
The password registered in the destination Advanced Box.
If you select [WebDAV] for the protocol:
Item
Description
Host Name
A host name is a name assigned to a host computer that provides services on the network. A specific host name is assigned to each host computer to identify it on the Internet. Here, enter the IP address or host name of the destination imageRUNNER ADVANCE series machine. If SSL is invalid: http://<IP address or host name> If SSL is valid: https://<IP address or host name>
Folder Path
A folder path is a series of characters that signify the location of the folder. Here, specify which folder under the Shared Space (share) or Personal Space (users) to save the document to. Example: \share\folder (To send to the [folder] folder in the Shared Space)
User Name
Password
When sending to the Advanced Box of another imageRUNNER ADVANCE series machine with an imagePASS attached, specify [Host Name] as indicated below.
To send to the Advanced Box of another machine with an imagePASS attached:
If SSL is invalid: http://IP address or host name:18080
If SSL is valid: https://IP address or host name:18443
You cannot store data directly in the Shared Space (share) or Personal Space (users) of the destination.
[User Name] and [Password] must be entered if user authentication is set for the destination Advanced Box.
To add another destination, press [Next Destination] → repeat steps 3 and 4.
5.
Press [OK].
