Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to Be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Copy Security with Forced Scan Lock
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Copying a Large Number of Documents Effectively with Two imageRUNNER ADVANCE (Cascade Copying)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Pausing Print Jobs to Change Settings (Hold)
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Security » Copy Security with Forced Scan Lock
08KE-26K
You can implement security measures such as Document Scan Lock to help prevent unauthorized copying and information leakage. This mode can be set by administrator so that it is always reflected on the output by the general users.
Document Scan Lock
This mode enables you to embed scan lock information and tracking information on the copies/prints to restrict job operation. When the output with embedded information is scanned, the machine restricts operation according to the specified settings of embedded scan lock information.
With this settings, you can restrict unauthorized copying/printing, and also analyze embedded information on the output and find out who, when, and with which machine the copy or print was made.
You can embed the information using the TL code.
Original
Copy/Print
Output
Copy/Store/Print
Jobs are restricted.
TL Code
The dots are printed in the background of output.
This section describes how to set the Forced Document Scan Lock function using the TL code to embed information.
Required Condition
You are logged in as the administrator.
The Document Scan Lock Kit is activated.
Follow the procedures below.
Setting Forced Document Scan Lock mode
Adjusting the Embedded Dots (TL Code)
Specifying the Document Scan Lock Operational Settings
You can specify the Forced Document Scan Lock mode.
Press (Settings/Registration) → [Function Settings] → [Common] → [Print Settings].
Press [Document Scan Lock Settings].
If the Secure Watermark is activated, press [Secure Watermark/Document Scan Lock].
Press [Forced Document Scan Lock].
If the Secure Watermark is activated, press [Forced Secure Watermark/Doc. Scan Lock].
4.
Press [Set] for <Copy>.
If the Secure Watermark is activated, press [Forced Doc. Scan Lock] for <Copy>.
5.
Press <Scan Lock Information>.
6.
Select [Prohibit All] → press [OK].
7.
Press <Tracking Information>.
8.
Specify each setting → press [OK].
Select [Set] for <Tracking Information>.
Select [Do Not Set] for <Password When Analyzing Embedded Info>.
9.
Press [OK].
Specify the settings for <Access Stored Files> and <Printer> as well.
You can adjust the size, density, etc. of dots embedded in the document as a TL Code.
Press [Adjust TL Code].
4.
Adjust the size and density of the dots.
Set '4' for <Dot Size>.
Select [Standard] for <Dot Density>.
5.
Press [OK].
You can select the device operations for when the embedded TL code is scanned.
Press (Settings/Registration) → [Function Settings] → [Common] → [Document Scan Lock Operational Settings].
Specify each setting.
Set <Use Document Scan Lock/Embedded Info.> to 'On'.
Set <Use Document Scan Lock> to 'On'.
Select [Cancel Job] for <Multiple Embedded Information Action>.
Set <Restrict Functions Affecting Doc. Scan Lock> to 'Off'.
Press [OK].
The Forced Document Scan Lock using the TL code are now set. When copying, printing, or scanning an original on this machine, the document scan lock information are embedded on the output. If the output is scanned, the job is canceled by the embedded TL code.
References
You can analyze embedded tracking information in the TL code printed on the output, and find out who, when, and with which machine the document was output.
For more information, see the manual for Document Scan Code Analyzer for MEAP.
