Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to Be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Copy Security with Forced Scan Lock
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Copying a Large Number of Documents Effectively with Two imageRUNNER ADVANCE (Cascade Copying)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Pausing Print Jobs to Change Settings (Hold)
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Internet Fax/Intranet Fax
08KE-262
What Is Internet Fax/Intranet Fax?
Internet Fax (I-fax) is a function that enables you to send and receive images via the Internet, as opposed to a telephone line.
The setup and method are the same as for e-mail. You can send image data as an attachment to an e-mail.
The sender scans an original and specifies a destination in the same way as a G3 FAX, and the receiver prints out the I-fax after receiving it from the POP server.
Using Intranet Fax you can send and receive I-fax between compatible imageRUNNER ADVANCE machines using office LAN with TCP/IP protocol. Data is transmitted directly with IP transmission, without the need for a mail server.
I-Fax System
Standards for I-fax are defined by ITU-T (International Telecommunication Union - Telecommunication Standardization Sector). You can send and receive with other manufacturer's machines as long as that machine is ITU-T compliant. The imageRUNNER ADVANCE is compliant with Recommendation T.37 (Procedures for the transfer of facsimile data via store-and-forward on the Internet).
Benefits of Using Internet Fax
Reduce transmission costs
G3 FAX transmission costs increase with transmission time and distance. If a line with fixed rate is installed, you can control the transmission cost because the cost of I-fax is fixed regardless of the transmission time and distance. It is recommended that you use this when sending and receiving large volume documents.
High resolution transmission
You can send and receive at a resolution of up to 600 dpi (for Full Mode).
Confirm transmission
The sender can be notified as to whether the document was received by the recipient.
Color transmission
You can send and receive color documents. Also, you can send and receive with another manufacturer's machine as long as that machine is ITU-T compliant.
Intranet-Fax System
Intranet Fax is a function unique to Canon machines.
Data transmission not using a mail server, referred to as IP Fax and compliant with ITU-T Recommendation T.38 (Procedures for real-time Group 3 facsimile communication over IP networks), is available on some other machines. However, these machines cannot perform Intranet Fax with Canon machines.
Benefits of Using Intranet Fax
Speedy
When sending e-mail or I-fax via a server, the data is not usually received instantaneously. This means that even if sending is completed, the data may remain in the server and may not have been received.
Intranet Fax transmits data between machines without using a server, meaning that the instant sending is completed, the data is received.
Image data is converted to TIFF (with color) files for sending and receiving.
Comparison of Sending Methods for the imageRUNNER ADVANCE
Fax
E-Mail
I-Fax with Simple Mode*
I-Fax with Full Mode*
Intranet Fax
Transmission Cost
Per transmission
Fixed rate
(leased line)
Fixed rate
(leased line)
Fixed rate
(leased line)
Fixed rate
(office LAN)
Speedy
Yes
No
No
No
Yes
Confirm Transmission
Yes
No
No
Yes
Resolution
Approx. 200 dpi
Up to 600 dpi
Up to 600 dpi
Up to 600 dpi
Up to 600 dpi
Paper Size
Up to 11" x 17"
Up to 11" x 17"
Up to 11" x 17"
Up to 11" x 17"
Up to 11" x 17"
File Format
TIFF
JPEG, TIFF, PDF, XPS, OOXML
TIFF
TIFF
TIFF
* The difference between Simple Mode and Full Mode for the imageRUNNER ADVANCE is whether delivery confirmation is available.
