Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to Be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Copy Security with Forced Scan Lock
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Copying a Large Number of Documents Effectively with Two imageRUNNER ADVANCE (Cascade Copying)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Pausing Print Jobs to Change Settings (Hold)
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Fax » Sharing Received Fax Documents in the Advanced Box
08KE-25S
By sending the received fax documents to the Advanced Box, you can share and view the documents without printing. The documents stored in the Advanced Box can be printed using a desired printer. For instance, when the machine receives a fax document, you can print the document using a printer nearby or a printer without fax lines.
Required Condition
Network settings are set.
Fax can be used.
The following settings are required to use the Shared Space of the Advanced Box.
[Use SMB Server] is set to 'On'.
(1)
Press (Settings/Registration) → [Preferences] → [Network] → [SMB Server Settings].
(2)
Set [Use SMB Server] to 'On' → press [OK].
[Open to Public] is set to [By SMB].
(1)
Press (Settings/Registration) → [Function Settings] → [Store/Access Files] → [Advanced Box Settings] → [Open to Public].
(2)
Select [By SMB] → press [OK].
[Prohibit Writing from External] is set to 'Off'.
(1)
Press (Settings/Registration) → [Function Settings] → [Store/Access Files] → [Advanced Box Settings] → [Prohibit Writing from External].
(2)
Select [Off] → press [OK].
This section describes the procedure for sending the received fax documents to the Shared Space in the Advanced Box which is opened to public by SMB, and printing the documents using a printer nearby.
The screens may differ, depending on the model of the machine and on attached optional products.
Follow the procedures below.
Creating a Folder in the Advanced Box
Registering an Address of the Folder
Setting the Forwarding Condition
Printing Fax Documents Using a Printer Nearby
Press [Scan and Store] on the Main Menu screen.
Press [Advanced Box].
Select [Shared Space].
4.
Press [Folder Operations].
5.
Press [Create Folder].
6.
Enter the folder name → press [OK].
A new folder is created.
Press (Settings/Registration) → [Set Destination] → [Register Destination] → [Register New Dest.].
Press [File].
Press [Name] → enter a name of the created folder → set [Host Name] and [Folder Path].
Name:
Enter a name for the file server.
Host Name:
Enter the IP address of the destination plus "/share" to save to the Shared Space.
example:
//172.24.23.187/share
Folder Path:
Specify the folder under the Shared Space (share).
4.
Press [Next] → [OK] → [Close] → [Close].
The address of the created folder is registered in the Address Book.
Press (Settings/Registration) → [Function Settings] → [Receive/Forward] → [Common Settings] → [Forwarding Settings] → [Forward w/o Conditions].
Press [Forwarding Destination].
Press [Address Book].
4.
Select the created folder for the destination.
5.
Press [OK].
6.
Press [Fwd Done Notice].
7.
Select the destination you want to send a forwarding done notice → press [OK].
8.
Press [OK].
9.
[Forward w/o Conditions] is displayed in the forwarding settings. Select [Forward w/o Conditions] → press [Validate/Invalidate] to set it to 'On'.
10.
Press [Close] → [Close].
All received fax documents are now sent to the created folder. When forwarding fax documents is complete, the forwarding done notice is sent to the specified address.
After receiving the forwarding done notice, access the created folder from the computer.
This section uses Windows 7 as an example.
Click [Start] → [Programs] → [Accessories] → [Windows Explorer] → enter the following path in [Address]. (case sensitive)
\\<IP address of this machine>
Select the [share] folder in the Advanced Box.
Open the created folder.
4.
Open the fax document and print it using a printer nearby.
