Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to Be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Copy Security with Forced Scan Lock
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Copying a Large Number of Documents Effectively with Two imageRUNNER ADVANCE (Cascade Copying)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Pausing Print Jobs to Change Settings (Hold)
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Department ID Management
08KE-265
What Is Department ID Management?
Department ID Management enables you to keep track of the copy and print totals for each department.
You can set an ID and password for each department, and manage the machine use for each ID.
Department ID Management is a function limited to users with a registered ID and password, and automatically records their use of the machine. You must enter a valid ID and password when copying or printing, and only one ID can be logged in at a time. This results in an accurate record of machine use for each ID.
If you install a Card Reader, you can use a card for authentication instead of entering an ID.
You can manage the number of pages used for each card, in the same way as an ID.
You can verify the totals for each ID from the machine's touch panel display, on the Print List, or via the Remote UI.
The Department ID Management and MG Counter totals may differ.
Authentication by card is only valid for copying. You cannot use a card to manage printing totals.
Features of the Department ID Management
Only users with a registered ID and password can use this function.
You can manage color and black-and-white copy/print totals for each ID.
You can set output restrictions for each ID.
Benefits from Using the Department ID Management
By restricting an ID to one department, you can prevent users from other departments from using the ID.
Totals for each ID can be used by the administrator as a guide when determining the budget. By setting an ID for each user, you can keep track of the number of pages printed on an individual basis.
By setting a page limit (maximum number of prints) for each department, you can promote the prevention of waste copying and printing.
Helps minimize paper use, making it beneficial for obtaining ISO14001 certification.
