Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding the Scanned Image via Network Scanner onto a Document
Enabling PDF Documents to Be Edited with Adobe Reader (Reader Extensions)
Converting Scanned Documents into the Encrypted Searchable PDF
Printer Driver
Merging and Printing Multiple Documents
Printing a Booklet (Windows)
Printing a Booklet (Mac)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Sharing Received Fax Documents in the Advanced Box
Sharing Sent Fax Documents in the Advanced Box
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box and Advanced Box
Storing and Sending a Document
Creating a Personal Space in the Advanced Box (Open to Public by WebDAV)
Creating a Personal Space in the Advanced Box (Open to Public by SMB)
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Copy Security with Forced Scan Lock
Preventing Other Users to See the Printed Documents
Hard Disk Data Security
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Copying a Large Number of Documents Effectively with Two imageRUNNER ADVANCE (Cascade Copying)
Printing and Copying with the Original Background Images
Printing Files Stored in the USB Memory Directly from the Machine
Printing Files Created with Different Applications as a Single File
Creating Address Labels by Scanning Business Cards
Pausing Print Jobs to Change Settings (Hold)
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Using Advanced Box (imageRUNNER ADVANCE Desktop)
Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Fax
Fax
08KE-25C
Receiving and Storing Faxes in Your imageRUNNER ADVANCE
The imageRUNNER ADVANCE offers a wide array of fax solutions, including the paperless fax feature. Documents received via fax are stored in digital form, benefiting the user by reducing paper costs, and enabling efficient management and productive reuse of digital documents.
Documents received via Fax, Internet Fax, and Intranet Fax are temporarily stored in the Memory RX Inbox of the machine's internal hard disk. The received documents can be processed as shown below.
Features of the Memory RX Inbox
All received documents are stored in the Memory RX Inbox, enabling uniform management.
The capacity of the Memory RX Inbox depends on the memory available in the machine's internal hard disk. The imageRUNNER ADVANCE 8205/8295/8285 has a capacity of 2,000 documents or 20,000 pages. However, these figures are only applicable if the machine's internal hard disk is being used solely for the Memory RX Inbox.
Received documents are stored in the Memory RX Inbox in a file format exclusively supported by this device.
Benefits of the Memory RX Inbox
By receiving and viewing a fax without printing, you can save on machine running costs such as paper, toner, and maintenance.
You can view a document received via fax without leaving your desk, increasing workplace efficiency and productivity.
Received documents can be shared via a computer, making the documents accessible to more people.
Even if you run out of consumables, you can view received documents on a computer.
