Top » Access Stored Files » Adjusting Printing to Fit the Paper Size
0C1Y-10U
You can adjust the size of a PDF or XPS file to match the paper size when printing.
If the page size in the PDF file exceeds the printable area on the actual paper to print, you can reduce the page size to print accordingly. You can also enlarge the page size to fit your paper size if the page size of the PDF or XPS file is smaller than the actual paper to print.
As an example, the procedure for printing files that are stored in memory media is explained in this section.
You can use this mode only when printing PDF or XPS files.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the location where the file you want to print is stored.
Select the desired file → press [Print] → [Select Paper].
4.
Press the paper source → press [OK].
5.
Press [Options] → [Match Paper Size] → [Close].
