Top » Access Stored Files » Arranging Files and Folders Stored in Memory Media » Previewing a File
Previewing a File
0C1Y-10A
You can preview the contents of files stored in memory media.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the directory where the file you want to display is stored.
Select the desired file → press [Display Image].
To preview an XPS file, the Direct Print Kit (for PDF/XPS) is required.
To preview an encrypted PDF file, it is necessary to enter the password on the password entry screen.
To preview a PDF file with a policy, it is necessary to enter the user information on the login screen.
4.
Press [OK].
