Top » Access Stored Files » Two-Sided Printing
Two-Sided Printing
0C1Y-10K
This mode enables you to print two successive pages of a stored file, on both sides of a sheet of paper.
As an example, the procedure for printing JPEG and TIFF files that are stored in memory media is explained in this section.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the location where the file you want to print is stored.
Slect the desired file → press [Print].
If you select a PDF or XPS file, proceed to step 5.
4.
Select the paper size → press [OK].
5.
Press [2-Sided Printing].
To change the paper source, see "Paper Selection."
6.
Select the type of finishing → press [OK].
[Long Edge]:
Uses the long edge of the paper as the binding location for the back and front sides.
[Short Edge]:
Uses the short edge of the paper as the binding location for the back and front sides.
7.
Press [Start Printing].
You may not be able to print, depending on the paper type.
Paper used to make two-sided prints must conform to the following specifications:
Paper size: LTR, LGL, STMT, EXEC (envelopes cannot be used for two-sided printing)
Paper weight: 17 to 28 lb bond (64 to 105 g/m2)
If there are an odd number of pages in the file, the back side of the last print is left blank. (The machine's counter does not count the blank page as a print.)
If you select a PDF file together with the Auto Select Paper mode, and the pages that you want to print are of different sizes, the pages are printed as one-sided prints on paper of their respective sizes. If you want such pages to be printed as two-sided documents, select the correct paper sizes in advance.
