Top » Access Stored Files » Convenient Modes for Printing
0C1Y-10L
You can use [Options] from the Print Settings screen to access a wide variety of print options to meet your needs.
You can set the Enlarge/Reduce mode, set the print resolution, and specify many other print options.
The options that you can use differ based on the file format. The following options are supported for each file type:
: Available -: Unavailable
Options
PDF File
XPS File
TIFF/JPEG File
[Match Paper Size]
[Enlarge Print Area]
[N on 1]
[Print Position]
[Halftones]
[Enlarge/Reduce]
[Image Orientation]
[Resolution]
[Password to Open a Doc.]
[Print Comments]
Depending on the mode, some combinations of modes are not available. (See "Unavailable Combination of Functions.")
