Checking File Information/Adding and Deleting Files
0C1Y-109
You can check the detailed information for files on the memory media (file name, location, date modified etc.), and add or delete files.
Checking the Detailed Information for a File
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the directory where the file you want to check is stored.
Select the desired file → press [Edit File].
4.
Press [Details] → [OK].
If you want to change the file name, press [Change File Name].
For information on the icons displayed on the Details screen, see
"Types of Network/Memory Media Icons."
Select the desired memory media → select the directory where the file you want to delete is stored.
4.
Press [Delete].
5.
Press [Yes].
Changing a File Name (Change File Name)
Select the desired memory media → select the directory where the file you want to change the file name is stored.
4.
Press [Change File Name].
If you select multiple files and press [Change File Name], the selected (highlighted) file becomes the file whose title is changed.
5.
Enter a file name → press [OK].
Adding a File (Scan and Store)
You can scan an original and store it as a file.
Place your originals.
Select the desired memory media → select the directory where you want to store the file.
4.
Press [Edit File].
5.
Press [Add Files (Scan and Store)].
6.
Specify the desired scan settings.
7.
Press
(Start).
If the following screen is displayed, after the last batch of originals is scanned, press [Start Storing].
If you place your original on the platen glass, press
(Start) to scan each original.
