[JPEG]:
Stores the file in the JPEG format only if you select a color mode other than [Black & White].
[TIFF]:
Stores the file in the TIFF format only if you select [Black & White] for the color mode.
[PDF]:
Stores the file in the PDF format regardless of the color mode. You can also select additional settings.
[XPS]:
Stores the file in the XPS format regardless of the color mode. You can also select additional settings.
[OOXML]:
Stores the file in the Office Open XML (pptx) format only if you select the Full Color mode or the Grayscale mode for the color mode.
You can select additional settings if you store the scanned file in the PDF, XPS, or OOXML format. Refer to the following for instructions on setting each type of PDF, XPS, or OOXML:
[Trace & Smooth]:Trace and Smooth
[Compact]:Compact PDF or XPS Files
[OCR (Text Searchable)]:Searchable PDF/XPS/OOXML Files
[Add Digital Signatures]:PDF or XPS Files with a Digital Signature
[Encrypt]:Encrypting PDF Files
[Apply Policy]:Applying a Policy
To view a JPEG file, software that supports the JPEG format (such as Microsoft Internet Explorer for Windows) is required.
To view a TIFF file, software that supports the TIFF format (such as Imaging for Windows) is required.
To view a PDF file or to search a text in a PDF file, software that supports the PDF format (such as Adobe Reader/Adobe Acrobat) is required.
To view an XPS file or to search a text in an XPS file, software that supports the XPS format (such as XPS Document Viewer) is required.
To view an OOXML file or to search a text in an OOXML file, software that supports the OOXML format (Microsoft Office PowerPoint 2007/2010) is required.
