Top » Scan and Store » Unavailable Combination of Functions
0C1Y-0YH
The following tables show the unavailable combinations of settings when you want to set more than one mode at a time.
Network/Memory Media
Function
Functions that Cannot Be Used in Combination
Platen Glass Scanning
Feeder Scanning, 2-Sided Original
Feeder Scanning
Platen Glass Scanning, Scan Size (Custom)
Scan Size (Auto (LTR/LGL))
Erase Frame
Scan Size (Custom)
Feeder Scanning
2-Sided Original
Device Signature (Visible)
Format PDF to PDF/A, Optimize PDF for Web*1, Encrypted PDF*2
Device Signature (Invisible)
User Signature (Visible)
User Signature (Invisible)
Compact PDF
Resolution*3, Auto (Color/Black), Black & White, Trace & Smooth PDF*4
Encrypted PDF
Format PDF to PDF/A, Apply Policy, User Signature*2, Device Signature*2
Trace & Smooth PDF
Resolution*3, Auto (Color/Black), Black & White, Compact PDF*4
User Signature*1, Device Signature*1
Apply Policy
Format PDF to PDF/A, Encrypted PDF
Format PDF to PDF/A
Apply Policy, Encrypted PDF, Device Signature (Visible), User Signature (Visible)
Compact XPS
OOXML (PowerPoint)
Searchable OOXML
JPEG
Resolution*5, Auto (Color/Black), Black & White, Divide into Pages*6
TIFF
Auto (Color/Black), Auto (Color/Gray), Grayscale, Full Color
Divide into Pages
JPEG*6
Erase Frame
Auto (Color/Gray)
Resolution*5, TIFF
Auto (Color/Black)
Resolution*5, TIFF, JPEG, Searchable OOXML, OOXML (PowerPoint), Compact XPS, Trace & Smooth PDF, Compact PDF
Full Color
Resolution*5, TIFF
Grayscale
Resolution*5, TIFF
Black & White
Resolution
Searchable OOXML*3, OOXML (PowerPoint)*3, Compact XPS*3, Trace & Smooth PDF*3, Compact PDF*3, JPEG*5, Full Color*5, Grayscale*5, Auto (Color/Gray)*5, Auto (Color/Black)*5
*1 If you select [Optimize PDF for Web], you can set one of the followings:
Device Signature
User Signature
*2 If [Password Required to Change Permiss.] is set, you must set [Allow Changes] to [Changes but Extract Pages] in order to set digital signature settings.
*3 Combination available if the resolution is 300 x 300 dpi.
*4 When [Trace & Smooth PDF] is set, [PDF (Compact)] is set to 'On'.
*5 Combination unavailable if the resolution is above 300 x 300 dpi.
*6 When [JPEG] is selected, [Divide into Pages] is set to 'On'.
