e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand all
Collapse all
Category Top
Overview of This Function
Network Settings
Network
Memory Media
Flow of Scan and Store Operations
Storing Originals on the Network
Storing Originals into Memory Media
Canceling a Job While Scanning
Storing Originals While Printing
Favorite Settings
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Switching the Color Mode
Setting the Resolution
Specifying the Orientation of the Original Image
Setting the File Format
Trace and Smooth
Compact PDF or XPS Files
Searchable PDF/XPS/OOXML Files
PDF or XPS Files with a Digital Signature
Encrypting PDF Files
Applying a Policy
Selecting the Original Type
Adjusting Density Manually
Adjusting Background Density
2-Sided Original
Erase Frame
Adjusting the Image Sharpness
Unavailable Combination of Functions
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Scan and Store
0C1Y-0XJ
You can cancel scanning and storing a document from the touch panel display, or by pressing
(Stop) on the control panel.
Press [Cancel] on the screen that appears while the machine is scanning.
Press [Yes].
You can also cancel scanning by pressing
(Stop).
Back to Top
