Top » Scan and Store » Specifying the Orientation of the Original Image
0C1Y-0XX
You can specify the orientation of an original placed on the platen glass or into the feeder as vertical or horizontal.
By properly specifying the orientation of the original, you can ensure a proper scan result.
As an example, the procedure for selecting memory media as the storage location is explained in this section.
Press [Scan and Store] → [Memory Media].
Select the memory media → select the destination folder → press [Scan].
Press [Orig. Content Orientation] → select the orientation of the original → press [OK].
The orientation types of originals are as follows:
[Portrait]
Portrait refers to an original in vertical orientation: the shorter edges are at the top and bottom of the original.
[Landscape]
Landscape refers to an original in horizontal orientation: the shorter edges are at the left and right of the original.
Place the original as follows:
For Originals in Portrait Orientation
For Originals in Landscape Orientation
Type of Original
Platen Glass
Feeder
Type of Original
Platen Glass
Feeder
