1
[Up]
Press to return to the upper level.
2
[Check Media Information]
Press to check the details of memory media.
3
![]() Press to remove the memory media.
1
[Clear Selection]
Press to cancel the selection of a file.
2
[Name]
Press to sort the files by name, in ascending or descending order.
[Date/Time] Press to sort the files by date/time, in ascending or descending order. |
3
![]() Press to update the contents of the memory media. |
4
[Display Image]
Press to view the contents of the selected file. |
5
[Folder Operations]
Press to display the menu for editing the folders in the memory media.
6
[Scan]
Your original is scanned and stored in the memory media.
7
[Edit File]
Press to display the menu for displaying the details for, deleting, or renaming the selected file.
8
[Up]
Press to return to the upper level. |
1
[Details]
Press to check the details of the selected file.
2
[Delete]
Press to delete files stored in the memory media. You can select and delete up to 32 files at a time.
3
[Change File Name]
Press to change a file name.
1
[Resolution]
Press to select the resolution for scanning.
2
![]() You can specify the following settings:
Register/Edit Favorite Settings
Change Default Settings
3
[Favorite Settings]
Press to recall scan settings or register frequently used settings in the Favorite Settings. |
4
[Scan Size]
Press to set the size of the original that you are going to scan.
5
[File Format]
Press to select the file format for the files to store.
6
[Original Type]
Press to select the type of original (text only, photo only, or both text and photo) you are going to scan. |
7
[File Name]
Press to assign the file a name. |
8
[Options]
Press to specify other settings. You can set useful scanning modes such as Sharpness and Erase Frame.
9
[Restore Defaults]
Press to cancel all settings. (The machine restores the default settings for Scan and Store.) |
10
[Orig. Content Orientation]
Press to specify the orientation of the original. |
11
[2-Sided Original]
Press if you are scanning a two-sided original.
12
[Select Color]
Press to select the color for scanning.
You cannot store documents in the memory media if there is no free space available.
For instructions on checking detailed information for memory media, see "Checking the Detailed Information for Memory Media."
For information on the types of icons displayed for memory media, see "Types of Network/Memory Media Icons."
For instructions on arranging folders, checking detailed information for the file, and editing/deleting files, see "Access Stored Files."
