      0SU0-04Y
      When an Error Message Appears
      An error message appears on the display if an operation problem occurs, such as when toner runs out or the memory is full. Check the information below for details about each message.
      Check that orange tape on the toner cartridge has been removed.
      Cleaning failed.
      Communication failed.
      Mem. full. Check error w/ Status Monitor key.
      Memory full. Process secure print jobs.
      Memory media is restricted.
      No Paper
      No response from host.
      Paper jammed.
      Printing is restricted.
      Replace drum unit.
      Rplc drum. Check error w/ Status Monitor key.
      Replace toner cart.
      Size/Settings Mismatch
      The remaining toner info. cannot be detected properly. A non-Canon cartridge or a cartridge with the wrong item number may be inserted, or no cartridge is inserted. Continue Use: Press OK Do Not Use: Press Stop
      Toner Low (Replacement Not Yet Needed)
      Use Remote UI to set info. necessary for authentication.
