      0SU0-04X
      Clearing Jams
      If a paper jams, <Paper jammed.> is displayed on the screen. Press to display simple on-screen solutions. If it is difficult to understand the procedures on the display, see the following sections to clear jams. Carefully read the precautions in Maintenance and Inspections before cleaning paper jams.
      <Remove paper from tray>
      Paper Jams in the Multi-Purpose Tray
      When removing the jammed paper, do not turn OFF the machine
      Turning OFF the machine deletes the data that is being printed.
      If paper tears
      Remove all the paper fragments to prevent them from becoming jammed.
      If paper jams repeatedly
      Tap the paper stack on a flat surface to even the edges of the paper before loading it into the machine.
      Check that the paper is appropriate for the machine.
      Check that no jammed paper fragments remain in the machine.
      Do not forcibly remove the jammed paper from the machine
      Forcibly removing the paper may damage parts. If you are not able to remove the paper, contact your local authorized Canon dealer.
      Paper Jams in the Left Side
      1
      Open the left cover.
      2
      Gently pull out the jammed paper.
      3
      Close the left cover.
      If there is paper loaded in the tray, remove it first. Then, follow the procedure below.
      1
      2
      When the screen shown below is displayed, use / to select <Yes>, and press .
      Paper Jams in the Paper Drawer
      1
      Pull out the paper drawer until it stops, and slightly lift the front side to remove it.
      IMPORTANT:
      Make sure to hold the paper drawer with both hands when you lift the front side, and remove it gently. Otherwise, you may damage the paper drawer by dropping it.
      2
      3
      Insert the paper drawer into the machine.
      Insert the paper drawer at an angle, and then push it in horizontally.
      IMPORTANT:
      Make sure that the paper stack is under the small tabs ().
      4
      Paper Jams in the Optional Paper Drawer
      1
      Open the left cover of the optional paper drawer.
      2
      3
      Close the left cover of the optional paper drawer.
      4
      Pull out the optional paper drawer until it stops, and slightly lift the front side to remove it.
      IMPORTANT:
      5
      6
      IMPORTANT:
      7
