Paper Type
Paper Weight
Paper Setting
on the Machine |
Plain paper
17 lb bond to 24 lb bond (64 to 90 g/m²)
<Plain>
Recycled paper
<Recycled>
Color paper
<Color>
Heavy paper
25 lb bond to 28 lb bond (91 to 105 g/m²)
<Heavy 1>
29 lb bond to 34 lb bond (106 to 128 g/m²)
<Heavy 2>
Envelope
<Envelope>
Thin paper
16 lb bond (60 to 63 g/m²)
<Thin>
Transparency
<Transparency>
Label
<Labels>
Do not use the following types of paper:
Wrinkled or creased paper
Curled or rolled paper
Torn paper
Damp paper
Very thin paper
Paper printed by a thermal transfer printer
Highly textured paper
Glossy paper
Paper handling and storage
Store the paper on a flat surface.
Keep the paper wrapped in its original package to protect the paper from moisture or dryness.
Do not store the paper in such a way that may cause it to curl or fold.
Do not store the paper vertically or stack too much paper.
Do not store the paper in direct sunlight, or in a place subject to high humidity, dryness, or drastic changes in temperature or humidity.
When printing on paper that has absorbed moisture
Steam may emit from the paper output area, or water droplets may form around the paper output area. There is nothing unusual about any of these occurrences, which occur when the heat generated from fixing toner on the paper causes moisture in the paper to evaporate (most likely to occur at low room temperatures).
